Moto Mods
  • Moto Mods
Moto Mods
Forum How to connect IMX230
Join Moto Mods to participate - click to join for free!
  • Subscribers 58 subscribers
  • Views 1875 views
al11062000
al11062000 over 7 years ago
Hi all,
We want to connect SONY IMX230 Camera Sensor with raspberry pi by using Moto Mods HAT Adapter Board. How to do it? Thank you.
  • Gough Lui
    Gough Lui over 7 years ago +1
    I'm not exactly sure of what you are trying to do: The Moto Mods HAT Adapter Board is used to connect Raspberry-Pi compatible HAT expansion boards to a compatible Motorola MotoZ mobile phone. You are mentioning…
  • Gough Lui
    Gough Lui over 7 years ago in reply to al11062000 +1
    You would have to design your own. Pinouts for modules vary depending on the module. Likewise, RPI pin-out is provided in schematics from the foundation. The problem is you will need to design your own…
  • Gough Lui
    • The Moto Mods HAT Adapter Board is used to connect Raspberry-Pi compatible HAT expansion boards to a compatible Motorola MotoZ mobile phone.
    • You are mentioning the Sony IMX230 - are you trying to connect this to a MotoZ or a Raspberry Pi?
    • In general, out of the box support for cameras through the CSI connector is limited to the Raspberry Pi camera products (IMX219 for V2, OV5647 for V1).
    • To use other cameras would require quite a lot of development effort - you will have to adapt whatever connection method to match that of the Raspberry Pi's flexible-flat-cable pin-out and write a suitable driver for it.
    - Gough
  • al11062000
    al11062000 over 7 years ago in reply to Gough Lui
    Thank you Gough.
    We try to connect to raspberry pi with IMX230 camera sensor module. Can you give me some suggestions about camera adapter board?
  • Gough Lui
    You would have to design your own. Pinouts for modules vary depending on the module. Likewise, RPI pin-out is provided in schematics from the foundation. The problem is you will need to design your own adapter, and you will need to somehow come up with a driver for it which probably requires some knowledge from Broadcom in regards to the VideoCore GPU - see these threads/posts for a bit of perspective:
    • https://www.raspberrypi.org/forums/viewtopic.php?t=24660
    • https://www.petervis.com/Raspberry_PI/Raspberry_Pi_CSI/Raspberry_Pi_CSI_Camera_Interface.html
    • https://www.petervis.com/Raspberry_PI/Raspberry_Pi_CSI/Raspberry_Pi_CSI-2_Connector_Specifications.html
    • https://www.petervis.com/Raspberry_PI/Raspberry_Pi_CSI/raspberry-pi-csi-interface-connector-pinout.html
    • https://www.petervis.com/Raspberry_PI/Raspberry_Pi_CSI/Raspberry_Pi_CSI_Camera_Module.html
    This is not something it seems many others have done, so you're really much on your own.
    - Gough
