Tektronix
  • Tektronix
Tektronix
Documents Analyse true power, power factor, efficiency, energy consumption and harmonics to the latest standards
Join Tektronix to participate - click to join for free!
  • Author Author: gwenwilcox
  • Date Created: 12 Oct 2017 9:02 AM Date Created
  • Last Updated Last Updated: 6 Oct 2021 9:23 PM
  • Views 623 views
This 1- to 3-phase power analyser is used for testing high efficiency power supplies, LED drivers, home appliances, inverters and drives.
Use it to analyse and document true power, power factor, efficiency, energy consumption and harmonics to the latest regulatory standards such as Level VI, Energy Star, CEC, IEC 62301 and more.
Powerful analysis software eliminates the need to write and maintain your own software:
  • Remotely monitor, analyse and log results
  • Set-up and run custom pass/fail tests
  • Default Applications menu for easy setup
  • View waveforms, harmonic graphs and trend charts
  • Wide 1 MHz bandwidth for high frequency harmonics
  • High 1 Ms/S sampling rate for a detailed picture
  • Test harmonics to 100th order
Explore the options here.
  • tektronix_power_analyser
  • power_analyser
  • power_analysis
  • power design
  • Power and Energy Efficiency
