Tektronix
  • Tektronix
Tektronix
Documents Perfect Vision Begins at the Probe Tip
Join Tektronix to participate - click to join for free!
  • Author Author: tech1
  • Date Created: 4 Dec 2008 4:38 PM Date Created
  • Last Updated Last Updated: 27 May 2012 12:23 AM
  • Views 583 views
Perfect Vision Begins at the Probe Tipimage
Precision measurements start at the probe tip. The right probes matched to your oscilloscope are vital to achieving the greatest signal fidelity and measurement accuracy. As the leader of probing technology, Tektronix offers the world’s largest and most respected line. Their ruggedness, reliability and long life add up to the best probe value on the market. And they’re complemented by an amazingly wide array of probe accessories for virtually every need.
Passive Probes
Passive probes provide ease-of-use and a wide range of measurement capabilities at an affordable price.
Low Capacitance Probes
Low-capacitance probes, also called Zo probes or controlled impedance probes, are passive probes that offer very low input capacitance.
Active Probes
Active probes offer excellent versatility and accuracy when measuring high-frequency signals from today’s complex circuits.
Differential Probes
Differential probes provide the highest CMRR, broad frequency range and minimal time skew between inputs, making them the best choice for accurate measurements on differential signals.
Current Probes
Current measurement systems make current measurements and calculations simple and easy.
Product information table:
Mftrs. Part No.Product DescriptionAdditional Information
P2220
1/10X, 7 MHz/200 MHz passive probe
Group together under Passive Probes
P3010
10X, 100 MHz passive probe
P6139A
10X, 500 MHz passive probeGroup together under Passive Probes
P6158
20X, 3 GHz low-capacitance probeLow-Capacitance Probes
P6243
10X, 1 GHz active probeUnder Active Probes
ADA400AADA400A
100X/10X/1X/0.1X, 1 MHz differential preamplifierGroup together under Differential Probes
P6246
1X/10X, 400 MHz differential probeGroup together under Differential Probes
A621
1000 ARMS, 50 kHz current probeGroup together under Current Probes
A622
70 ARMS, 100 kHz current probeGroup together under Current Probes
P6021
7 ARMS, 60 MHz current probeGroup together under Current Probes
P6022
3 ARMS, 120 MHz current probeGroup together under Current Probes
TCP202.TCP202.
15 A, DC to 50 MHz current probeGroup together under Current Probes
TCP312TCP312
30 A, DC to 100 MHz current probeGroup together under Current Probes
TCP305
50 A, DC to 50 MHz current probeGroup together under Current Probes
TCP303TCP303
150 A, DC to 15 MHz current probeGroup together under Current Probes
TCP404XLTCP404XL
750 A, DC to 2 MHz current probeGroup together under Current Probes
P5100
100X, 250 MHz, passive high-voltage probeGroup together under High Voltage Probes
P5120
20X, 200 MHz, passive high-voltage probeGroup together under High Voltage Probes
P6015AP6015A
1000X, 75 MHz, passive high-voltage probeGroup together under High Voltage Probes
P5200
50X/500X, 25 MHz high-voltage differential probeGroup together under High Voltage Probes
P5205
50X/500X, 100 MHz, high-voltage differential probeGroup together under High Voltage Probes
P5210
100X/1000X, 50 MHz high-voltage differential probeGroup together under High Voltage Probes
  • at:manufacturer_news
  • sp:tektronix
  • date:1_11_08
