Vishay
  • Vishay
Vishay
Forum Verify the enclosed LED dimmer circuit using Triac BT136 and MOC3021 circuit
Join Vishay to participate - click to join for free!
  • Replies 15 replies
  • Subscribers 9 subscribers
  • Views 4874 views
chintan
chintan over 4 years ago
  I am Chintan Gopani. We have designed the Dimmer circuit using Triac BT136 and MOC3021 and Zero crossing detection circuit and other peripheral devices. Our application is to dim the standard dimmable LED lights fixtures in the USA.
  Our application is based on the USA market. I attached the design file for the review.
  I request you that please schedule the call with a technical person for the design improvement.
  • chintan
  • chintan
    PFA circuit design file
    michaelkellett over 4 years ago in reply to chintan
    Have you tried simulating this design ?
  • chintan
    chintan over 4 years ago in reply to michaelkellett
    Yes i tried, but it is flickering during the dimming LED light while i used LED light. So, please give me the appropriate solution for the same.
    If you were to show us your simulation data it might be possible to help. What simulation tool did you use ?
  • chintan
    We have not done the simulation we have making the our circuit on General Purpose Board (GPB) and done the testing with LED light
    OK, so show us pictures and test results - no one can help you without enough information to undertsnad your proble,.
  • chintan
  • chintan
    chintan over 4 years ago in reply to chintan
    PFA the testing results
  • chintan
    Here input Supply voltage is 230V AC, 50Hz
