Vishay
  • Vishay
Vishay
Forum Verify the enclosed LED dimmer circuit using Triac BT136 and MOC3021 circuit
Join Vishay to participate - click to join for free!
  • Replies 15 replies
  • Subscribers 9 subscribers
  • Views 4887 views
chintan
chintan over 4 years ago
  I am Chintan Gopani. We have designed the Dimmer circuit using Triac BT136 and MOC3021 and Zero crossing detection circuit and other peripheral devices. Our application is to dim the standard dimmable LED lights fixtures in the USA.
  Our application is based on the USA market. I attached the design file for the review.
  I request you that please schedule the call with a technical person for the design improvement.
    michaelkellett over 4 years ago in reply to chintan
    This isn't quite what I had in mind.
    Do you have an ocilloscope ?
    You will need to take precautions re. isolation of mains AC voltages to do any measuring here.
    If you do not understand why this is necessary or do not know how to safely measure mains powered equipment then you will need to find someone to do the work for you.
    It will not be possible to debug this design without checking waveforms with a scope.
    Is this a commercial project (ie are you designing something which you wish to amkes and sell) ?
  • chintan
    chintan over 4 years ago in reply to michaelkellett
    Yes, This is commercial project
  • chintan
    It is working fine with Incandescent light bulb without any flcikring. we are dimming the bulb by PWM signal with 50Hz frequency i.e. waveform has T=20ms. And based on that we are changing the duty cycle as per zero-crossing detection
  • chintan
    chintan over 4 years ago in reply to chintan
    But it is flicker while we used LED bulb and it is flickering while brightness has been increased above 70%
    Without scope traces of waveforms it is not possible to make any useful comment.
