Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Forum 10Base-T1L PoDL application, isolation?
Join Würth Elektronik to participate - click to join for free!
  • Subscribers 78 subscribers
  • Views 1271 views
  • ethernet
  • podl
  • 10Base-T1
  • 10Base-
PBlumberg
PBlumberg over 3 years ago
Dear all,
we're implementing 10Base-T1L in our device at the moment. The device is to be installed in a switch cabinet in industrial environment and is powered via 24VDC external power supply.
- Does the 1.5kV isolation requirement for network ports apply to the equipment and if so
- How should one achieve the 1.5kV isolation when implementing PoDL, where power is injected via a differential choke? Shall a 1.5kV isolation DC/DC converter be used for the PoDL supply?
My design below is inspired by the Wuerth SPE physical interface at ⁣Single Pair Ethernet | Application Guide | Würth Elektronik (we-online.com)
  • Würth Elektronik
    Würth Elektronik over 3 years ago
    Indeed, SPE requires 1.5kV of isolation in all industrial applications. The Power Supply for PoDL therefore has to be isolated as well - both on the supply and the load side.
    You can find more information on isolated converters in our Application Guide:
    https://www.we-online.com/de/components/applicationguide/appguide_power_distribution
  • PBlumberg
    PBlumberg over 3 years ago in reply to Würth Elektronik
    Thank you for clarification!
