Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Documents Dip Switches
  • Author Author: sleuz
  • Date Created: 26 Jul 2012 6:59 AM Date Created
  • Last Updated Last Updated: 28 Oct 2013 9:39 AM
  • Views 1933 views
Dip Switches
WE-Logo.jpgDip Switches
1.27 mm small compact SMD flat actuator with top tape WS-HP
WE Order CodeNumber of polesA
(mm)
Connection TypePitch
(mm)
ActuatorSwitch PositionWashabilityPackaging UnitDesignDelivery Ex StockTyp of switch Farnell Order Code
MATERIAL
InsulatorPA 46 UL HB
Flamability ratingUL94-V0
ColourBlack
Contact materialCopper alloy
Contact platingGold plated
Terminal platingGold plated
ENVIRONMENTAL
Operating Temperature-40°C up to 85°C
ComplianceLead free and RoHS
image41613116080223.58SMT1.27Flat typeOffyes3000HorizontalYesDip Switch
1868000 1868000
image41613116080446.12SMT1.27Flat typeOffyes2000HorizontalYesDip Switch
1868001 1868001
ELECTRICAL
Contact rating25mA, 24VDC
Dielectric withstanding voltage300 VAC/mn
Contact resistance50 mΩ
Electrical life1000 cycles/25mA, 24VDC
MECHANICAL
Pitch1.27 mm
SOLDERING
Solder temperatureReflow process as per JEDEC J-020D-STD
PACKAGING
PackagingReel
Switch PositionOff
image41613116080668.66SMT1.27Flat typeOffyes2000HorizontalYesDip Switch
1868002 1868002
image416131160808811.20SMT1.27Flat typeOffyes2000HorizontalYesDip Switch
1868003 1868003
image4161311608101013.74SMT1.27Flat typeOffyes2000HorizontalYesDip Switch
1868004 1868004
2.54 mm small compact SMD flat actuator with top tape WS-IC
(mm)
(mm)
ActuatorSwitch PositionWashabilityPackaging UnitDesignDelivery Ex StockTyp of switchFarnell Order Code
MATERIAL
ColourBlack
ENVIRONMENTAL
image41812116080112.98SMT2.54Flat typeOffyes2000HorizontalNoDip Switch20651442065144
image41812116080225.52SMT2.54Flat typeOffyes2000HorizontalYesDip Switch20651452065145
image41812116080338.06SMT2.54Flat typeOffyes1000HorizontalNoDip Switch20651462065146
image418121160804410.60SMT2.54Flat typeOffyes1000HorizontalYesDip Switch20651472065147
image418121160805513.14SMT2.54Flat typeOffyes1000HorizontalNoDip Switch20651482065148
ELECTRICAL
Dielectric withstanding voltage500 VAC/mn
Electrical life2000 cycles/25mA, 24VDC
MECHANICAL
Pitch2.54 mm
SOLDERING
PACKAGING
PackagingReel
Switch PositionOff
image418121160806615.68SMT2.54Flat typeOffyes1000HorizontalYesDip Switch20651512065151
image418121160808820.76SMT2.54Flat typeOffyes1000HorizontalYesDip Switch20651522065152
image4181211608101025.84SMT2.54Flat typeOffyes1000HorizontalYesDip Switch20651532065153
image4181211608121230.92SMT2.54Flat typeOffyes1000HorizontalYesDip Switch20651542065154
2.54 mm compact THT right angled with flat actuator WS-RA
(mm)
(mm)
MATERIAL
InsulatorPBT / PA66
ColourRed
Terminal platingTin plated
ENVIRONMENTAL
image41821717090226.08THT2.54Flat typeOffno85Right AngledYesDip Switch18680051868005
image418217170904411.16THT2.54Flat typeOffno47Right AngledYesDip Switch18680061868006
image418217170906616.24THT2.54Flat typeOffno32Right AngledYesDip Switch18680081868008
ELECTRICAL
MECHANICAL
Pitch2.54 mm
SOLDERING
Solder temperatureWave soldering, 260°C 10sec. max
PACKAGING
PackagingTube
Switch PositionOff
image418217170908821.32THT2.54Flat typeOffno24Right AngledYesDip Switch18680091868009
image4182171709101026.40THT2.54Flat typeOffno20Right AngledYesDip Switch18680101868010
2.54 mm compact SMD piano type with flat actuator WS-PT
(mm)
(mm)
MATERIAL
InsulatorPPS / HTN / PA46
ColourBlack
ENVIRONMENTAL
image41831117080226.08SMT2.54Flat typeOffno700Piano TypeYesDip Switch18680111868011
image418311170804411.16SMT2.54Flat typeOffno500Piano TypeYesDip Switch18680121868012
image418311170806616.24SMT2.54Flat typeOffno500Piano TypeYesDip Switch18680131868013
ELECTRICAL
MECHANICAL
Pitch2.54 mm
SOLDERING
PACKAGING
PackagingReel
Switch PositionOff
image418311170808821.32SMT2.54Flat typeOffno500Piano TypeYesDip Switch18680141868014
image4183111708101026.40SMT2.54Flat typeOffno500Piano TypeYesDip Switch18680151868015
-follow us on element14-
  • electronic
  • small
  • flat_actuator
  • compact
  • top_tape
  • interconnect
  • dip
  • electromechanical_solutions
  • smd
  • switches
  • würth
  • elektronik
  • wurth_elektronik
