Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Documents Common Mode Power Line Choke - WE-CMBH
  • Author Author: sleuz
  • Date Created: 23 Jul 2012 11:23 AM Date Created
  • Last Updated Last Updated: 28 Oct 2013 9:45 AM
  • Views 1287 views
Common Mode Power Line Choke for ultra-slim products
With the WE-CMBH series Würth Elektronik now also offers a common mode power line choke in a horizontal version. With a profile height of only 22 mm the power line choke is ideal for slim housings.
Due to low-capacitance winding technology, suppression over a wide band is now possible. This makes the WE-CMBH an excellent choice for interference suppression in the frequency range from 150 kHz to 30 MHz.
The product is available with inductance values from 1 mH up to 7 mH with a nominal current of up to 10 A.
In power electronics the WE-CMBH is used as power filter and output filter as well as in motor interference suppression. Würth Elektronik specifies the operating temperature range as –40 to +125 °C.
Characteristics:
  • horizontal design for compact housings
  • suppression even at low frequency ranges
  • broadband screening because of low capacitance winding technique
  • highest possible current with small sizes
  • customer specific designs on request
  • operating temperature: -40°C to +125°C
Applications:
  • Power electronics
  • Power line in- and output filter
  • Radio interference suppression in motors
  • suppression for common mode noise
WE order codeCoil RatioL
(mH)
IR
(A)
RDC
(mΩ)
UT
(V (AC))
UR
(V (AC))
DesignFarnell order code
74483410121.010.012.51500250THT20668562066856
74483462222.26.022.01500250THT20668572066857
74483443323.35.037.01500250THT20668582066858
74483440525.04.050.01500250THT20668592066859
74483440727.03.580.01500250THT20668602066860
-follow us on element14-
  • suppression_in_motors
  • wuerth
  • components
  • emv
  • emc
  • interference
  • emi
  • passive
  • würth
  • radio
  • common_mode_noise
  • elektronik
  • electronics
  • power
  • line_in-_and_output
  • filter
  • wurth_elektronik
