Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Documents High Speed Data Line Protection - WE-TVS TVS Diode
  • Author Author: sleuz
  • Date Created: 27 Nov 2012 8:50 AM Date Created
  • Last Updated Last Updated: 28 Oct 2013 9:40 AM
  • Views 568 views
WE-TVS TVS Diode – High Speed Serieshttp://i.imgur.com/j3A3X.png
The High Speed Series is your best choice to protect high speed data lines like USB 2.0, DVI or LAN from over-voltage caused by Electrostatic Discharge (ESD), Electrical Fast Transients (EFT) and lightning strikes (Surge) with a very small capacitance.The Power Line Series is your preferred component to protect power lines or low speed data lines from ESD, EFT and Surge. There are uni- and bidirectional components available. The WE-TVS series exceeds the requirements outlined in IEC 61000-4-2. The different available pin configurations and case sizes let you get your suitable part.
CharacteristicsApplications
  • Low clamping voltage
  • Sturdy design
  • Very low capacitance
  • Flow Thru Design for a simple layout
  • Rail to Rail protection
  • Epoxy flame resistant UL94-V0
  • RoHS, REACH and free of halogens
  • Very fast data lines
  • USB 2.0
  • Ethernet
  • PoE
  • VGA
  • Sim Cards
  • Keypads
http://katalog.we-online.de/media/images/eisos/VarTVS_highspeed_pf2.jpg
SOT563
WE Order Code
Channels
VDC
(V)
VBR
(V)
CCh
(pF)
CCross
(pF)
IPeak
(A)
ILeak
(μA)
ICh Leak
(μA)
VClamp
(V)
VCh Clamp ESD
(kV)
VESD Contact
(kV)
VESD Air
(kV)
Application
Farnell  Order Code
PDF
82400152
2+1
5
6
2
0,4
6
5,0
1,0
7,7
10
8
15
USB 1,0 – 2,0 Flow Thru Design
18258741825874
SC70-6L
WE Order Code
Channels
VDC
(V)
VBR
(V)
CCh
(pF)
CCross
(pF)
IPeak
(A)
ILeak
(μA)
ICh Leak
(μA)
VClamp
(V)
VCh Clamp ESD
(V)
VESD Contact
(kV)
VESD Air
(kV)
Application
Farnell  Order Code
PDF
82400274
4+1
5
6
1,2
0,1
6
5,0
1,0
8
12,5
12
16
Ethernet, USB 1,0 – 2,0 Double Port
18258761825876
SOT23-6L
WE Order Code
Channels
VDC
(V)
VBR
(V)
CCh
(pF)
CCross
(pF)
IPeak
(A)
ILeak
(μA)
ICh Leak
(μA)
VClamp
(V)
VCh Clamp ESD
(V)
VESD Contact
(kV)
VESD Air
(kV)
Application
Farnell  Order Code
PDF
824013
4+1
3,3
4,5
3
0,4
12
5,0
1,0
6
9
24
30
3,3 V Operating Systems
18258691825869
PDF
82400102
2+1
5
6
2
0,4
6
5,0
1,0
7,7
10
8
15
18258751825875
PDF
824015
4+1
5
6,1
2
0,1
12
5,0
1,0
7,8
13
12
20
17486151748615
PDF
824001
4+1
5
6,2
1
0,1
5
2,0
1,0
9
14
8
15
17486131748613
SOT23-5L
WE Order Code
Channels
VDC
(V)
VBR
(V)
CCh
(pF)
CCross
(pF)
IPeak
(A)
ILeak
(μA)
ICh Leak
(μA)
VClamp
(V)
VCh Clamp ESD
(V)
VESD Contact
(kV)
VESD Air
(kV)
Application
Farnell  Order Code
PDF
824011
2+1
5
6,1
2
0,1
12
5,0
1,0
7,8
13
12
20
USB 1,0 – 2,0
17486161748616
SOT143-4L
WE Order Code
Channels
VDC
(V)
VBR
(V)
CCh
(pF)
CCross
(pF)
IPeak
(A)
ILeak
(μA)
ICh Leak
(μA)
VClamp
(V)
VCh Clamp ESD
(V)
VESD Contact
(kV)
VESD Air
(kV)
Application
Farnell  Order Code
PDF
8240136
2+1
3,3
4,5
3
0,4
12
5,0
1,0
6
9
24
30
  1. 3.3 V Operating Systems
18258701825870
PDF
8240116
2+1
5
6,1
2
0,1
12
5,0
1,0
7,8
13
12
20
USB 1,0 – 2,0
18258711825871
PDF
8240026
2+1
5
6
1,2
0,1
6
5,0
1,0
8
12,5
12
16
USB 1,0 – 2,0
18258731825873
-follow us on element14-
  • tvs-diode
  • ethernet
  • fast_data_line
  • low_capacitance
  • rail_to_rail_protection
  • poe
  • keypads
  • sturdy_design
  • simple_layout
  • protection
  • vga
  • high_speeds
  • low_clamping_voltage
  • sim_cards
  • usb_2.0
