Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Documents Earthing and Grounding SMD EMI Contact Fingers - WE-SECF
  • Author Author: sleuz
  • Date Created: 4 Dec 2012 10:24 AM Date Created
  • Last Updated Last Updated: 28 Oct 2013 9:38 AM
  • Views 1285 views
WE-SECF SMD EMI Contact Fingers
http://i.imgur.com/j3A3X.png
The WE-SECF series from Würth Elektronik offers great protection against corrosion due to its gold-plated copper beryllium material and can be SMD assembled.
The contacts are not affected by mechanical forces or high temperatures.
http://katalog.we-online.de/media/images/eisos/AbsSESF_pf2.jpg
CharacteristicsApplications
  • suitable for automated placement
  • Material: copper-beryllium (CuBe) gold-plated (AU)
  • Different types and sizes available
  • Corrosion-resistant
  • Wear-resistant
  • High temperatures and mechanical weight have no influence on the excellent connection properties
  • Reliable solderability
  • Customize materials and platings are possible
  • Customized types and sizes are possible
  • Contact between PCB's earth and housing
  • Low Ω HF connection  between earthing points of two PCB's lying upon each other
  • Earthing of cooling units on high frequency
  • Connection between signal and power supply of two PCB's on track
  • Connection between PCB's and extern elements
0148
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Material
Farnell Order Code
PDF
331011452048
4,6
2
4,8
Copper-Beryllium (CuBe) golded (AU)
22498952249895
0315
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Material
Farnell Order Code
PDF
331031271520
3,2
1,5
1,5
22498962249896
0320
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Material
Farnell Order Code
PDF
331031321515
2,7
1,5
2
22498972249897
0453
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Material
Farnell Order Code
PDF
331041402053
4,1
2
5,3
22498982249898
0557
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Material
Farnell Order Code
PDF
331051472057
4,7
2
5,7
22498992249899
0610
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Material
Farnell Order Code
PDF
331061603010
6
3
10
22499012249901
0825
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Material
Farnell Order Code
PDF
331081302025
3
2
2,5
22499022249902
1440
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Material
Farnell Order Code
PDF
331141352540
3,5
2,5
4
22499032249903
1562
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Material
Farnell Order Code
PDF
331151702562
7,15
2,5
6,2
22499042249904
1670
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Material
Farnell Order Code
PDF
331161452070
4,5
2
7
22499052249905
1613
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Material
Farnell Order Code
PDF
331161702513
7
2,5
13
22499062249906
1730
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Material
Farnell Order Code
PDF
331171302030
3,15
2
3
22499072249907
1735
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Material
Farnell Order Code
PDF
331171302035
3
2
3,5
22499082249908
2140
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Material
Farnell Order Code
PDF
331211503040
5
3
4
22499092249909
2240
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Material
Farnell Order Code
PDF
331221602040
6
2
4
22499102249910
-follow us on element14-
  • cooling_units
  • wurth_electronics
  • pcb_contact
  • earthing_points
  • contact_fingers
  • earthing
  • signal_and_power_supply
  • earth_and_housing
  • extern_elements
  • high_frequency
  • hf_connection
  • wurth_elektronik
