Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Documents Board Shields - WE-SHC
  • Author Author: sleuz
  • Date Created: 13 Feb 2013 3:41 PM Date Created
  • Last Updated Last Updated: 14 Feb 2013 9:23 AM
  • Views 928 views
WE-SHC Shielding Cabinethttp://i.imgur.com/j3A3X.png
CharacterisiticsApplications
  • Tin plate in accordance with DIN EN 10202/10203
  • Shielding effectiveness up to 55 dB
  • Two-part case consisting of a solderable grid frame (SMD/THT) and a removable cover
To prevent EMI radiation from PCB and to keep sensitivity low of:
  • RF output stages
  • RF input and amplifier stages
  • Oscillators
  • EMC sensitive parts in plastic cases
http://katalog.we-online.de/media/images/eisos/AbsSHC_dimfixweb.jpg
WE Order Code
L
(mm)
W
(mm)
H
(mm)
Shielding
Effectiveness
@ 1 GHz
(dB)
Farnell Order Code
PDF
36003200
20
20
3
60
19096591909659
PDF
36003250
25
25
3
60
19096621909662
PDF
36003300
30
30
3
60
19096651909665
PDF
36003500
50
50
3
60
19096691909669
PDF
36003600
60
60
3
60
19096721909672
WE Order Code
Order Code
Top Cover
Design
L
(mm)
W
(mm)
H
(mm)
Shielding
Effectiveness
@ 1 GHz
(dB)
Farnell Order Code
PDF
36103205
36003200
SMD
20
20
3
60
19096571909657
PDF
36103255
36003250
SMD
25
25
3
60
19096601909660
PDF
36103305
36003300
SMD
30
30
3
60
19096631909663
PDF
36103505
36003500
SMD
50
50
3
60
19096671909667
PDF
36103605
36003600
SMD
60
60
3
60
19096701909670
WE Order Code
Order Code
Top Cover
Design
L
(mm)
W
(mm)
H
(mm)
Shielding
Effectiveness
@ 1 GHz
(dB)
Farnell Order Code
PDF
36503205
36003200
THT
20
20
3
60
19096581909658
PDF
36503255
36003250
THT
25
25
3
60
19096611909661
PDF
36503305
36003300
THT
30
30
3
60
19096641909664
PDF
36503505
36003500
THT
50
50
3
60
19096681909668
PDF
36503605
36003600
THT
60
60
3
60
19096711909671
follow Würth Elektronik on element14
  • emi_radiation
  • oscillators
  • rf_output_stages
  • rf_input_and_amplifier_stages
  • emc_sensitive_parts
