Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Documents Press-Fit Technology
  • Author Author: ophilpott
  • Date Created: 21 Feb 2011 2:12 PM Date Created
  • Last Updated Last Updated: 7 Oct 2021 8:33 AM
  • Views 691 views
Press-fit technology is one of the core competences of the Würth Elektronik Intelligent Connecting Systems.
before / after
Thanks to the specific benefits of press-fit technology for printed circuit board connectivity, effective problem solutions become both possible and practical, for example 
  • Elimination of complex and fault-prone wiring  
  • Simple realisation of plug and play systems  
  • Simple realisation of three-dimensional design through right-angled press-fit connectors  
  • Compact realisation of keypads and control panels   
The benefits of press-fit technology 
As compared with conventional solder technology, the use of press-fit technology shows a number of advantages:
  • possibility for populating both sides of the printed circuit board without added expense  
  • elimination of thermal stress of the printed circuit board  
  • elimination of soldering errors such as, for example, cold solder places, solder short-circuits, …   
  • screw mountings are no longer necessary  
  • elimination of flux residues which can result in contact faults  
  • in comparison to machine soldering, size restriction of the assemblies to be processed no longer has to be considered  
  • long plug connector posts remain clean (no solder) and can be used as male connectors on the other side of the board  
  • assemblies with press-fit technology are also best suited for high-frequency applications as printed circuit board impedances can be specifically defined  
  • simplification of repairs due to easily exchangeable connectors  
  • high environmental compatibility  
solder technology
Würth Elektronik ICS have specialised in the implementation of solid press-fit technology for high current applications. In a series of theoretical and experimental investigations, we could scientifically prove that solid press-fit technology is outstandingly suitable for use in this area due to the optimum electrical properties. 
  • press_fit
  • sp:wuerth
