Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Documents Tact & Rotary Switches
  • Author Author: sleuz
  • Date Created: 26 Apr 2012 12:48 PM Date Created
  • Last Updated Last Updated: 28 Oct 2013 9:31 AM
  • Views 1568 views
Expanded Switch Seriesimage
Würth Elektronik expands its extensive portfolio of switches for the electronics industry, adding three new series to the product line of switches.
WS-TST - Tact switches 6x6 mm right angle type with grounded terminal
Models of the series WS-TST are available in size 6×6 mm. Their covering of these THT switches are made of carbon steel plate, as are its contacts which have an additional layer of plated silver. With silver-plated connections and with actuator and housing of LCP UL 94V-0, the switches are not only lead-free and RoHS-compliant, but also suitable for operating temperatures between -40 and +85° C. Switches of this size feature a contact rating of up to 50 mA, 12 VDC, contact resistance of 100 MΩ @500 VDC, dielectric strength of 250 VAC/min and contact resistance of 100 mΩ max.
WE Order CodeOperation force
(g)
Height
(mm)
BetätigerfarbeIsolation Resistance
(MΩ)
Life cyclePackaging UnitFarnell Order Code
image431256031716160 +/-503.15schwarz> 100 @ 500VDC200 00050020651312065131
image431256038716160 +/-503.85black> 100 @ 500VDC200 00050020651342065134
image431256031726260 +/-503.15white> 100 @ 500VDC200 00050020651322065132
image431256038726260 +/-503.85white> 100 @ 500VDC200 00050020651352065135
image431256031736360 +/-803.15salamon> 100 @ 500VDC200 00050020651332065133
image431256038736360 +/-803.85salamon> 100 @ 500VDC200 00050020651362065136
WS-TSW - Tact switches 12x12 mm
Models of the series WS-TSW are available in size 12×12 mm. Their covering is made of carbon stainless steel, as are its contacts which have an additional layer of plated silver. With silver-plated connections and with actuator and housing of LCP UL 94V-0, the switches are not only lead-free and RoHS-compliant, but also suitable for operating temperatures between -40 and +85° C. Switches of this size feature a contact rating of up to 50 mA, 12 VDC, contact resistance of 100 MΩ @500 VDC, dielectric strength
(g)
Height
(mm)
(MΩ)
image430466043726260 +/-704.3white> 100 @ 500VDC300 0005020651412065141
image430466073726260 +/-707.3white> 100 @ 500VDC300 0005020651422065142
image430466085726260 +/-708.5white> 100 @ 500VDC300 0005020651432065143
image430456043736360 +/-904.3salamon> 100 @ 500VDC200 0005020651382065138
image430456073736360 +/-907.3salamon> 100 @ 500VDC200 0005020651392065139
image430456085736360 +/-908.5salamon> 100 @ 500VDC200 0005020651402065140
WS-RAT - Rotary switches 7x7 mm THT
Models of the series WS-RAT are available in size 7x7 mm. Their covering is made of stainless steel, as are its contacts which have gold plating. With gold-plated connections and with actuator and housing of LCP UL 94V-0, the switches are not only lead-free and RoHS-compliant, but also suitable for operating temperatures between -60 and +125° C. Switches of this size feature a contact rating of up to 100 mA, 42 VDC, contact resistance of 100 MΩ @500 VDC, dielectric strength of 250 VAC/min and contact resistance of 100 mΩ max. This series is available with 10 and 16 positions and with real and complement code.
WE Order CodeBetätigerfarbePositionCodeOperation force
(g)
(MΩ)
image428547320910red10Real120 g +/-30> 100 @ 250VDC25 0007020651552065155
image428547320911orange10Complement120 g +/-30> 100 @ 250VDC25 0007020651562065156
image428547320916grey16Real120 g +/-30> 100 @ 250VDC25 0007020651572065157
image428547320917ivory16Complement120 g +/-30> 100 @ 250VDC25 0007020651582065158
-follow us on element14-
  • sheet
  • wuerth
  • components
  • rotary
  • tht
  • smd
  • switches
  • passive
  • pdf
  • electromechanical
  • tact
  • data
  • wurth_elektronik
