Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Documents Flat Wire Inductor WE-PDF  from Wurth Electronics
  • Author Author: sleuz
  • Date Created: 7 May 2012 11:37 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 4:52 AM
  • Views 1127 views
New  Flat Wire Inductor WE-PDF from Wurth Electronicsimage
  • extended temperature range
  • increasing efficiency of your application
  • lower AC-Resistance
  • fits on many standard footprints of common manufacturers
  • 2 different sizes – 1045 low profile, 1064 standard
Würth Electronics released a new high performance flatwire inductor series, available in 10x10x4mm and 10x10x6mm. The WE-PDF consists of ferrite material having significantly lower core losses than iron powder inductors, which is mainly used in high current inductor designs.
The WE-PDF series is optimized for power supplies running high switching frequencies. Due to the focus on high performance partial components for the design, this series has been released for an extended temperature range up to 150 degree celcius.
The flatwire uses the whole winding window by using the maximum available area on the core to reach the minimum of the DCR.
And second, by using the flatwire, the AC resistance is much lower as for roundwire inductor designs.
Characteristics:
• size:  10,2 x 10,2 mm
• low profile:  6.4 mm
• switching frequency range:  up to 10 MHz
• Operating Temperature:  up to 150°C
• L-value  0.22uH - 30uH
• high  IRMS:  up to 10.3 A
• high  ISAT:  up to 30A
• low DCR:  6.2mΩ to 43mΩ
Get the data sheet here...
        rated up to 150°C
Typical Applications:        Extended use in non-typical applications:
•     Multiphase Converters        ---> released operating temperature
•     High Frequency Converters
•     High Current Converters        -40°C to +150°C      (instead of -40°C/+125°C)
•     Motherboards
•     Industrial Computers                                                              designed to ensure the use in applications like:
•     Set Top Boxes
•     FPGA Power Supplies                                                           ’’automotive like’’
        industrial
        adverse environmental conditions
        extreme exceeding ratings of standard components
Standard Series|Low-Profile Series
Man. Part No.
Description
Farnell Part No.
|Man. Part No.DescriptionFarnell Part No.
7447798022 (pdf)
SMD, 10x10x6,4 0,22µH 19,00A, 1064
1800273|7447797022 (pdf)
SMD, 10x10x4,5 0,22µH 16,00 A, 1045
1800262
7447798050 (pdf)
SMD, 10x10x6,4 0,50µH 18,50A, 1064
1800274|7447797050 (pdf)
SMD, 10x10x4,5 0,50µH 13,20 A, 1045
1800263
7447798110 (pdf)
SMD, 10x10x6,4 1,10µH 16,50A, 1064
1800275|7447797110 (pdf)
SMD, 10x10x4,5 1,10µH 11,20 A, 1045
1800264
7447798111 (pdf)
SMD, 10x10x6,4 11,0µH   6,90A, 1064
1800285|7447797180 (pdf)SMD, 10x10x4,5 1,80µH  9,40 A, 10451800266
7447798131 (pdf)
SMD, 10x10x6,4 13,0µH   5,85A, 1064
1800286|7447797360 (pdf)SMD, 10x10x4,5 3,60µH  8,20 A, 10451800269
7447798151 (pdf)
SMD, 10x10x6,4 15,0µH   5,45A, 1064
1800287|7447797470 (pdf)SMD, 10x10x4,5 4,70µH  6,20 A, 10451800270
7447798180 (pdf)
SMD, 10x10x6,4 1,80µH 14,50A, 1064
1800276|7447797620 (pdf)SMD, 10x10x4,5 6,20µH  5,70 A, 10451800271
7447798181 (pdf)
SMD, 10x10x6,4 18,0µH   5,00A, 1064
1800288|7447797820 (pdf)SMD, 10x10x4,5 8,20µH  5,05 A, 10451800272
7447798221 (pdf)
SMD, 10x10x6,4 22,0µH   4,70A, 1064
1800289|
7447798241 (pdf)SMD, 10x10x6,4 24,0µH   4,50A, 10641800290|
7447798250 (pdf)SMD, 10x10x6,4 2,50µH 13,70A, 10641800277|
7447798271 (pdf)SMD, 10x10x6,4 27,0µH   4,30A, 10641800291|
7447798360 (pdf)SMD, 10x10x6,4 3,60µH 12,00A, 10641800278|
7447798470 (pdf)SMD, 10x10x6,4 4,70µH   9,50A, 10641800281|
7447798620 (pdf)SMD, 10x10x6,4 6,20µH   9,40A, 10641800282|
7447798720 (pdf)SMD, 10x10x6,4 7,20µH   7,90A, 10641800283|
7447798910 (pdf)SMD, 10x10x6,4 9,10µH   7,35A, 10641800284|
-follow us on element14-
  • current
  • wuerth
  • motherboards
  • components
  • industrial
  • emv
  • emc
  • multiphase
  • top
  • flat
  • passive
  • würth
  • fpga
  • converters
  • wire
  • dcr
  • boxes
  • computers
  • low
  • high
  • switching
  • supplies
  • power
  • solutions
  • inductor
  • wurth_elektronik
  • set
  • range
  • isat
  • frequency
