Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Documents Card Connectors WR-CRD
  • Author Author: sleuz
  • Date Created: 5 Jun 2012 11:58 AM Date Created
  • Last Updated Last Updated: 6 Aug 2013 1:00 PM
  • Views 2491 views
Würth Elektronik WR-CRD Series for SIM, SD, microSD and compact flash cardsimage
DescriptionWE Order CodePins
Working voltageContact resistanceFarnell Order Code
SIM Card Connector (Mini SIM) Header - 6 pins WR-CRD
(pdf)
693 010 010 601650 V (AC)50mΩ20813562081356
SIM Card Connector (Mini SIM) Header Shielded - 6 pins WR-CRD
(pdf)
693 010 020 611650 V (AC)50mΩ20813572081357
SD Card Connector Push & Push - with Card Detection - 9 pins WR-CRD
(pdf)
693 061 010 9119100 V (AC)100mΩ20813592081359
SIM Card Connector (Mini SIM) Header Shielded - W/O card stop - 6 pins WR-CRD
(pdf)
693 010 030 601650 V (AC)50mΩ20813582081358
SD Card Connector Push & Pull - with Card Detection - 9 pins WR-CRD
(pdf)
693 063 010 9119100 V (AC)100mΩ20813602081360
SD Card Connector Push & Pull - Short Type - with Card Detection - 9 pins WR-CRD
(pdf)
693 063 020 9119100 V (AC)100mΩ20813612081361
Micro SD Card Connector Push & Push - 8 pins WR-CRD
(pdf)
693 071 010 8118100 V (AC)100mΩ20813632081363
Micro SD Card Connector - Hinge - 8 pins WR-CRD
(pdf)
693 072 010 8018100 V (AC)100mΩ20813642081364
Compact Flash Card Connector - Header - 50 pins WR-CRD
(pdf)
693 120 015 01150100 V (AC)40mΩ20813652081365
Compact Flash Card Connector - Header - Reverse type - 50 pins WR-CRD
(pdf)
693 120 025 01150100 V (AC)40mΩ20813662081366
Compact Flash Card Connector - Header - Shrouded type - 50 pins WR-CRD
(pdf)
693 120 035 01150100 V (AC)40mΩ20813672081367
-follow us on element14-
  • connectors
  • pull
  • compact
  • push
  • components
  • emv
  • emc
  • passive
  • würth
  • sim
  • flash
  • elektronik
  • electromechanical
  • mini
  • card
  • sd
  • wurth_elektronik
