PCB Design, Prototyping and Production
PCB Blogs USB to Banana Plug Adapter
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Author Author: dougw
  • Date Created: 16 Nov 2022 7:54 AM Date Created
  • Views 48256 views
  • Likes 13 likes
  • Comments 6 comments
  • USB to banana plug adapter
dougw
dougw
16 Nov 2022
This blog is to make available the USB to Banana Plug adapter design in case anyone else wants to build one.
This adapter converts a standard 2 pin banana jack to a USB connector and a 0.1" pitch header. This allows bench power supplies to test USB devices with any voltage and current. It also allows USB cables to be tested for voltage drop.
Here is a picture showing this simple adapter:
Here is a quick video explaining the adapter:
The zip file of PCB manufacturing artwork I used to have these cards built is attached. It can be sent as is to a PCB fab shop.
USBpower.zip
I used banana plugs like this.
Incidentally, I have made other PCBs that can convert banana plug cables to USB:
 The Missing Link (BBC-PCB)
Indicate in the comments if you plan to build a module like this or if you have any questions.
    dougw over 3 years ago in reply to genebren
    That looks like what I was doing before - and why I made a PCB. If USB connectors were built to accept cables, it might not have been necessary.
    genebren over 3 years ago
    Very cool idea.  I have recently been building a USB based device and as part of my bring-up procedure, I first power the board from a current limited power supply to minimize and potential damage from construction faults (shorts, reversed components, etc.).  I have been using a salvaged USB connector with some soldered on leads, but I can clearly see that you are onto a much more robust solution.  Here is a picture of my poor attempt to do a similar thing:
    I think that I might need to build something similar to yours, but adapted a bit to suit my power supply.
    Thanks for sharing a great idea!
  • baldengineer
    baldengineer over 3 years ago
    Thanks Doug!
    Like I said before, I was already thinking to make something like this, but I think I’ll just use your design!
    iI appreciate the warning about the spring too.
  • rsjawale24
    rsjawale24 over 3 years ago in reply to dougw
    yes, it's there now
    dougw over 3 years ago in reply to rsjawale24
    It takes time to get all the data in sync. I can't seem to get videos to upload directly, so I have to send them to Youtube first.
    I want the Youtube video to show a link to the element14 blog so I have to publish the blog to get the link before I can embed the video. etc.
    Hopefully it is all there now....
