PCB Design, Prototyping and Production
PCB Forum The Advanced QFN
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Subscribers 162 subscribers
  • Views 1460 views
The Advanced QFN
scottiebabe
scottiebabe over 4 years ago
Soft 404
  • wolfgangfriedrich
    wolfgangfriedrich over 4 years ago +2
    This would be a good candidate for https://twitter.com/cursedfootprint?lang=en Should be possible to solder with a stencil and a lot of heat. The PCB itself would be pricey with via in pad required and…
    dougw over 4 years ago +2
    Maybe you could try applying solder balls: https://www.pcbbuy.com/news/How-to-make-a-solder-ball.html re-balling is a fairly standard process for smt rework, but not a normal hobby process.
  • wolfgangfriedrich
    wolfgangfriedrich over 4 years ago in reply to scottiebabe +2
    I have seen some amazing self-centering action with regular QFNs. As long as you drop the part less than 1/2 pad off center, you are pretty much golden. Easy talking, I know... Edit: I just noticed th…
  • wolfgangfriedrich
    Should be possible to solder with a stencil and a lot of heat. The PCB itself would be pricey with via in pad required and capped/filled vias recommended.
  • scottiebabe
    scottiebabe over 4 years ago in reply to wolfgangfriedrich
  • wolfgangfriedrich
    Edit: I just noticed th larger pads in the corners, they help a lot to move the part when the solder is melted.
  • wolfgangfriedrich
    wolfgangfriedrich over 4 years ago in reply to dougw
    Ha, this site has the same colour design as e14, I was confused for a while.
    Brilliant idea with the solder balls. This would make placement and hot air/reflow much easier at home.
