Raspberry Pi
Raspberry Pi
Blog A Dummies Guide to Linux on a Raspberry Pi. - 1.0
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: phoenixcomm
  • Date Created: 29 Jul 2015 6:42 PM Date Created
  • Views 4452 views
  • Likes 17 likes
  • Comments 32 comments
  • raspberry-pi
  • computing_history
  • unix
  • sudo_open
  • operating_systems
  • introduction
  • linux
  • raspberry_pi_getting_started
phoenixcomm
phoenixcomm
29 Jul 2015
Introduction:
    Linux you say what is Linux? Alright, I know how I will begin. A long time ago in the mid 70's at Bell Laboratories, Murry Hill, New Jersey, a two guys came up with Unix. They were: Denis Ritchie and Ken Thompson. Here is a little film which explains it.
This was the eureka moment for computing. At that time the world changed. You see everything up to then was done in what is known a fixed length records. You sat and punched you cards and then took them to the "Computer Room" and gave them your cards. Hopefully you did not have any errors, or you had to fix the problem, and then go back to the "Computer Room".  Unix is device independent. You know in Dos/Windows (1983/5) you used to have to install your printer through your program? And then to print your document you first have to open the program to get to the printer. Well, that's gone!So to print a document/file pick it up and drag it to your local printer icon (should be on your desktop), and it asks how many copies and which printer to print it on. This printer could be in your office out in the hall, or on the other side of the world. The reason is  Unix, programs write, read to Standard I/O. And all files are just that files there are no special files like the directories. There just normal files.
    Now you may be asking; what does Unix have to do with Linux? Well, Unix came first. If you wanted it you had to go to Bell Labs and get a license sometimes in source and build it yourself.  Unix was mostly in colleges and university's. Some folks like Sun Microsystems bought the source license and built SunOS (1981)  and then Solaris (1993). Richard Stallman (1981-85) Created GNU.  Berkley University came out with BSD. And a guy named Andrew S. Tanenbaum created MINIX at Vrije Universiteit in Amsterdam to exemplify the principles conveyed in his textbook, Operating Systems: Design and Implementation (1987). This book also contained abut 12k lines of source.
Now comes another guy (1991) a Finnish student Linus Torvalds created a new kernel and called it Linux. So in a way you could call Linux, a child and Unix the parent. This makes my head hurt, I'll let you strain you eyes and you head.
In the video, they said two things; small programs (utilities),  do the work and make life easier. Since they read and write to standard input and output. This means that one program's output to another program's input, you can chain as many programs as you like to get the job done. This is called a pipe ( | [symbol]). Unix and Linux are multi-treaded out of the box, the other feature is redirection in windows you might have used dir > filename, but in Unix/Linux we have standard I/O so you could do this: filename > program > filename.
In Windows you have shortcuts..  we have something much better, we have link & ulink lets say I use a directory that is not in my home directory what you can make a "Symbolic Link": ln -s target directory  local-name.  So link is ln and ulink is the unlink command.
One more thing Unix/Link we think of our hard drives (/dev/sda) separately from the data. If you had a second hard drive (/dev/sdb). One more thing a hard drive has partitions they are numbered 1, 2, 3 etc. So your drive would be  defined has /dev/sdb4 (second drive, fourth partition.
Now to volumes, a volume is just a logical group of files, this can be more than one partition and multiple drives. Food For Thought:
(long version with both -al options)
harrison@Whirlwind
~ $ ls -al /mnt/MyData/user/harrison > /home/harrison/mnt_directory.txt
total 48
drwx------9harrisonharrison4096Jul 25 21:26.
drwxr-xr-x5rootroot4096Jul 25 20:58..
drwx------3harrisonharrison4096Apr  5 16:23export
drwxr-xr-x4harrisonharrison4096Jul 26 11:52home
drwx------2harrisonharrison4096Jul 28 14:12ISO
drwx------2rootroot16384Mar 14 10:00Lost+found
drwx------30harrisonharrison4096Jul 29 08:20public
drwx------4harrisonharrison4096Feb 13  2015SOFTWARE
drwx------7harrisonharrison4096Jun 28  2014Zotero_Data
(short version without arguments)
harrison@Whirlwind
~ $ ls
export  home  ISO  lost+found  public  SOFTWARE  Zotero_Data
Now after the first command was issued and you did a ls  here is what you will have:
harrison@Whirlwind
~ $ ls
export  home  ISO  lost+found  public  SOFTWARE  Zotero_Data mnt_directory.txt
The alphabet soup in front of the files are as follows:
  • d is directory if blank or - means it just a file
  • Then in groups of three of three: r  read, w write, execute.
  • The three groups are OWNER, GROUP, WORLD
  • There is one more it's not shown t or sticky bit (if you need it please look it up yourself)
  • number of links
  • OWNER
  • GROUP
  • File Size
  • Time/Date file was last modified.
  • File name or Directory name
Now I will take apart the long command piece by piece.
  1. Green  you have the username@machine_name.
  2. Blue you have the user prompt.
  3. The ls command with options (-al) a is all files, and l is long
  4. The commands target /mnt/MyData/user/harrison
  5. Redirect the output and create a new file.
OK, just one more thing while we are talking about the ls command. Unix/Linux always knows where the current directory is, so if you issue a ls without any options or target. It would list the current directory. So guess what when you get confused you can alway ask for it. This command is pwd or print working directory.
Stay Tuned More To Come
~~Cris H. image
  1. A Dummies Guide to Linux on a Raspberry Pi.
  2. A Dummies Guide to Linux on a Raspberry Pi. - 2.0 Distros
  3. TBA the reviews...
  • chris_b
    chris_b over 8 years ago +3
    Wow! This Chart wakes little nostalgic feelings in me. I touched, more or less every derivative on this Chart since 1988. Started my career with Sinix on MX500 Systems from Siemens, followed by Reliant…
    dougw over 8 years ago in reply to phoenixcomm +2
    Would that make android a grandchild of UNIX?
  • jomoenginer
    jomoenginer over 8 years ago +2
    Linus did not initially create the Linux kernel, he created a program using MINUX ( A Unix-like OS but not derived from Unix) and GNU C compiler to control hardware on his x386. He initially wanted to…
  • phoenixcomm
    phoenixcomm over 7 years ago in reply to shabaz
    Ditto on the SunBlade but mine was called 3d Creator, 2x 500Mhz CPUs with a Crap Load of memory! it's a freeken beast! I might fire it up though to do the flight simulation model which uses quaternion and fixed point math which this box will just munch! To take this to another level thing which requires degrees, they have to be converted to fixed point 16-bits BAMS for a dial gauge or flight instrument and for navigation then we use 32-bit BAMS for any spot on the earth (resolves to about a postage stamp! This is faster than an x86 flavor of the day.even at 3GHz and dual cores its not even close as most of the fixed point math can be done in 1 Cycle ie Clock Cycle on the SPARC and G-d only knows on the x86!! image
    BTW with a BAM, you can perform normal math on them +, -, *, / and you will always get the right answer. As a BAM is 2(n-1) Where n is the base you are using, ie 8, 16, 32. So it is representative of a number between 0 and 2(n-1) the only time when you have to convert <> is when you wish to display | enter a number in DMS and while we're at it N/S and E/W also disappear. So basically if you have 270deg + 270deg in BAM back to decimal speak BAM + BAM = 180 deg when converted back to decimal speak. lets see you do that with DMS (*** get real ugly). If you could use an 8-bit BAM you would end up with 0 to 255 or ~1.4 parts of a circle. But the Human Eye can see .3  So you really need 16-bit BAMS or about .01. image
    shabaz over 7 years ago in reply to phoenixcomm
    Ohh interesting!. I did work with such PBXs too.
    Snoop brings back memories : ) And it was a great name for a network tool.
    I still have a Sun Blade 2000 (desktop) although not powered up, in the shed. I think the Sun logo glowed.
    (photo from google image search):
    It's a beast. List price >$10k when new.. and not really a desktop machine, since it takes up half the desk : )
    I hoped to remove the insides (just being practical, since I'm unlikely to nowadays install Solaris on it - and it's not a rare or nice-looking machine, so not worth preserving!) and fit a large motherboard (2 x Xeon chips) but when I attempted that, realized it was almost impossible without major work, since the chassis does not have hole positions and slots that suit PC motherboards : (
    The Sun Enterprise 450 however looked really cool. If I had a large lab I'd buy one to turn it into a minibar/fridge : )
    (picture via google image search)image
    Jan Cumps over 7 years ago
    Solaris is the first system I did unix development on. It was the OS of choice when running Oracle ERP on Oracle managed servers and services.
    Later they migrated to Dell and Linux. My conspiracy theory is that they did it as part of bringing SUN’s stock price down before hitting them with a hostile takeover ... image
  • phoenixcomm
    thoughts were the days. DTrace and many other apps. Like Snoop. The only failure I ever had was a fan died in one of my Sun VME boxes that were in my garage before I did my big ISP thing. My only failure was a FAN when out and I died about 12 noon on a Saturday.  My local Electronics Store was about to close like 12:30 I told them to wait for me I'm on my way.. about 2 hours later the box was up and running again.
    The Monitors were made by Sony and I loved them (This is my second web server),
    Heres a pick of my big-iron Cisco 7600?? router with 2 DSL DSU plugged into it. The two boxes above the router are R-MON probes! Fun time here!! And for shits and giggles blow is the picture of my Nortel phone PBX, we had two customers total of ten locations handled by this thing plug my phones.
  • phoenixcomm
    phoenixcomm over 7 years ago in reply to jomoenginer
    " The field person had to run a cable from a cube outside of the Lab through the ceiling tiles to the Lab for a private network to the HP Storage Array." yea you should have seen some of the *** I had to deal with in one building downtown years ago I worked for a large law firm they where spread out over 4 floors, ie lots of seats! We paid for the floor to be cored. but the lazy bastards cored to the channel and ran my fiber down the elevator shaft...
    Duh, you guess,  you got it my pager when off. the elevator had ripped the cables. Lucky me I had spools of terminated fiber in my truck when to the fiber interface and plugged them in the threw them both down the stairwell! then I ran upstairs and did the same thing. Got it all working so the fiber did not get damaged I had a star chisle and pounded them through the walls (all three)  then went back and used paper clips to hang the fiber near the ceiling!  We jointly sued the building and won a very large settlement!! whoopie.
