Raspberry Pi
Raspberry Pi
Blog DeepWhisper: Hunting Ghosts with Raspberry Pi and Artificial Intelligence
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: e14phil
  • Date Created: 26 Oct 2017 11:58 AM Date Created
  • Views 5196 views
  • Likes 8 likes
  • Comments 6 comments
  • node red
  • halloween
  • raspberry pi project
  • project
  • google
  • raspberry pi
  • sharethescare
  • spooky
  • raspberrypi
  • nodered
  • node
  • ghosts
  • rpi_beginner
  • google ai
e14phil
e14phil
26 Oct 2017
Matt Reed from RedPepper has used a Raspberry Pi, Microphone, a Creepy Doll and  Google’s Speech Neural Network system to listen into .... Ghosts.
"From October 27–31, we’ll be live streaming the DeepWhisper rig nightly from our offices in historic “Butchertown” Nashville so you can watch for any EVPs that may come through. Just the thing to do at 3am when you can’t sleep." - Matt Reed
The DeepWhisper Project  pipes a real-time microphone stream to Google’s Speech Neural Network, which can detect over 110 languages and then we’llimmediately display the results as they come back
www.DeepWhisper.io
Deep Whisper is Opensource so anyone can hunt their own ghosts.
it runs on Node and its libraries have been optimized for Raspberry Pis. You’ll need a USB microphone, Google Cloud Platform Project Key, a display, and patience.
Matt will upload a full repository link soon but, for now, here are the key code snippets.
Connecting to Google Voice Neural Network
You’ll need to have a project set up in the Google Cloud Platform console which will grant you an authentication JSON key that your app will use to connect. Just follow these steps to get that going. Note: you may have to set up billing with Google to proceed.
// Authenticate with Google Cloud
const speech = require('@google-cloud/speech')({
  projectId: 'deepwhisper-XXXXXXXX',
  keyFilename: 'Deepwhisper-XXXXXXX.json'
Streaming mic input to Google
Simply pipe the microphone input to Google, and if the Neural Network detects speech in any of the 110+ supported languages, it will be returned as a string of transcript text.
// Connect and listen to USB microphone
const micInstance = mic({
  rate: ‘16000’,
  channels: ‘1’,
  debug: true,
  exitOnSilence: 0
const micInputStream = micInstance.getAudioStream();
micInputStream.pipe(recognizeStream);
// Create a real-time recognize stream with Google
const recognizeStream = speech.streamingRecognize(request)
  .on(‘error’, console.error)
  .on(‘data’, (data) =>
  (data.results[0] && data.results[0].alternatives[0])
    ? io.emit('text', { transcript: data.results[0].alternatives[0].transcript })
    : `\nReached transcription time limit, press Ctrl+C\n`);
Display the results
Using a simple HTML page with Socket.IO, you can receive the results emitted by the server above and display them immediately. This uses jQuery to set the text and fade it out after five seconds.
<script>
  var socket = io.connect('http://localhost:3000');
  socket.on('text', function (data) {
  $('#transcript').text(data.transcript);
  $('#transcript').fadeIn();
  setTimeout(function(){
  $('#transcript').fadeOut(function(){
  $('#transcript').text('');
  }, 5000);
</script>
Source and Project Matt Reed at RedPepper.land
www.DeepWhisper.io
    DAB over 9 years ago +1
    I like it. Plus you now have a sound detector. DAB
  • gam3t3ch
    gam3t3ch over 9 years ago +1
    Now the microphone what are you using? are we using a usb condensor microphone like a yeti or blue snowball? Personally I think running through a mixer with phantom power with an omnidirectional microphone…
    balearicdynamics over 9 years ago +1
    I like so much! Need more video showing ghosts ... Enrico
    I like it.
