Raspberry Pi
Raspberry Pi
Blog First run of Raspberry Pi 4
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: kk99
  • Date Created: 7 Sep 2019 5:16 PM Date Created
  • Views 2336 views
  • Comments 8 comments
  • happybirthdaye14
kk99
kk99
7 Sep 2019
I have downloaded latest Raspbian and flashed it with balenaEtcher tool to SD card. Under Linux it is done by following command:
./balenaEtcher-1.5.56-x64.AppImage
My idea is to have headless system, so I enabled SSH and configured a connection to home WiFi network. To enable SSH we need to create a empty file called shh under following location /boot/ on SD card. To setup WiFi we need to create a file with following name: wpa_supplicant.conf at the same location. Here is template of WiFi configuration file:
country=us
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
    ssid="NETWORK-NAME"
    psk="NETWORK-PASSWORD"
After that we could boot our RPi4 from micro SD card. Now we could log in remotely via SSH with following parameters: pi/raspberry. To achieve better performance I have order a aluminum heat sink for RPi4. Below photos of RPi4 with installed heat sink.
To check temperature difference with/without heat sink I have installed a tool called sysbench and performed a ~10 minutes CPU stress test. It could be done with following command:
sysbench --num-threads=4 --cpu-max-prime=90000 --test=cpu run
Below are results for run without and with heat sink:
With installed heat sink the CPU temperature is around 20 degrees of Celsius less.
Below there is description for project which I would like to made with usage of RPi4:
My idea is try to use of RPi4 as streaming device with usage of adaptive bitrate streaming technologies. As source I would like to use a USB dongle with DVB-T which be source of one MUX. The chosen channels will be transcoded e.g. by ffmpeg software. The final data will be segmented and distributed with one of technologies e.g. HLS over HTTP. Below there is diagram for this idea:
  • kk99
    kk99 over 6 years ago in reply to colporteur +4
    1. Yes, is made from aluminum. 2. Yes, there is access to connectors. 3. Yes. I bought it on ebay, here is link to shop: https://www.ebay.pl/itm/New-CNC-Aluminum-Radiator-Protective-Case-Enclosure-Heat…
    genebren over 6 years ago +2
    Pretty cool!
  • ralphjy
    ralphjy over 6 years ago +2
    Might be an interesting project to try with ATSC for those of us in the US. If you are successful, maybe I could just change the front end and use your setup.
  • kk99
    kk99 over 6 years ago in reply to ralphjy
    Sure, I will check what kind of performance we could achieve. I wonder if ffmpeg could is able to use Broadcom transcoders.
  • ralphjy
    Pretty cool!
