Raspberry Pi
Raspberry Pi
Blog PiCade Build and Test
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: dougw
  • Date Created: 2 Sep 2019 3:31 AM Date Created
  • Views 5397 views
  • Comments 12 comments
  • doug wong
  • picasso
  • picassotizer
  • pimoroni
  • picade
  • picasso design challenge
dougw
dougw
2 Sep 2019
As a finisher prize in the PiCasso Design Challenge I received a Pimoroni PiCade and a Raspberry Pi 3B+ to power it.
This blog is is an unboxing / build / test of that system.
The build actually took several hours and getting the software properly configured took a bunch more hours.
The kit is complete (except for the Raspberry Pi and a power supply) and there were even some spare parts left over (I assume they are spare parts image)
Every thing fit without being forced and it seems solidly designed.
The only mechanical issue I had was the spade terminals connecting to the power switch LED were too tight - they need to be carefully opened up a bit.
The buttons don't snap into place because the panels are too thick for the switch design, but they are a tight enough fit that I don't expect them to pop out. If the do get too loose, a dab of glue would solve it.
The display is much higher resolution and quality than the TVs these games were originally developed for, so in some ways it has a modern look and feel to it, right down to longer boot times.
I found it was possible to hang the system up in a state where no button does anything - even the power button. Part of the problem might be that when setting up the button preferences, I couldn't set the Hot key - it wouldn't accept any buttons I wanted, so it defaulted to the Select button. The Hot key sort of exits from the current program when pushed. However in some menus this prevents selecting a menu choice and jumps back to another menu in an endless cycle.  In particular I cannot "select" to change the Hot key. Hopefully there is a file or something I can edit to fix it.
If you are building one in North America, beware that the keyboard default is set for the UK and you will have to set the keyboard to "US" before you can follow the installation instructions.
There is a pretty good guide to building here:
https://learn.pimoroni.com/tutorial/sandyj/assembling-your-picade
It is pretty impressive that games developed for multiple platforms can run on this system and it is a very nice scale to enjoy the gaming experience, but it is quite a bit more complex than your average game box. Just the assembly alone is quite a project, and you pretty much need a a keyboard and another computer to get everything working properly.
Overall, the PiCade is a pretty solid system that can take the kind of pounding typically encountered in action games, so although you can run Retropie on any Raspberry Pi, if you want the console and arcade experience you will have to build something like this.
    balearicdynamics over 7 years ago in reply to ntewinkel +6
    Nico, without any other help than the poster with the assembly instructions I spent about one hour and a half to set up all the stuff until the boot worked. It is true that there is not a micro SD but…
    dougw over 7 years ago in reply to balearicdynamics +4
    It would be great if I could somehow get all my Amiga software running on it.
  • ntewinkel
    ntewinkel over 7 years ago +4
    I just watched your videos this morning on YouTube, Doug Maybe it took longer because your little furry friend wasn't there to lend a paw? Looks like a very nice unit, with some pretty solid looking parts…
    shabaz over 7 years ago
    Hi Doug,
    That looks really great! The image quality looks excellent - better that old arcade games systems : )
    Also it's very cool they've used arcade-game-like controls, and that the computer just blends away, so that it's like a real arcade system.
    Nico, without any other help than the poster with the assembly instructions I spent about one hour and a half to set up all the stuff until the boot worked. It is true that there is not a micro SD but it has the sense as you could see the PiCade just like a common HAT, as well as an Arduino shield. The point is that the kit does not include the Raspberry Pi. So, it is expected - as a normal user, not a victim of the generosity of Element14 image - that you already own your Raspberry PI or you bought one by yourself.
    With this scenario, the workflow IMHO is the following:
    1. I am fa an of retro games and in some way, I approached the Raspberry PI.
    2. I decided to install the RetroPie version of Raspbian, that is almost all set to run
    3. Then I am happy with my new tool but I should consider to buy or adapt or I already own a sort of a controller, or playing my games with issues directly with the keyboard
    4. The next step is buying (maybe together with the PI but from a different marketing environment) the PiCade kit.
    5. I assemble it, spending less than two hours or about half a day if I am a beginner.
    And until this point, I don't see anything special or difficult, I think.
    Then there are a couples issues, related to the legal problems of the ROM you should learn how to manage them correctly (I have not yet understood very clear how-to). And this is the problem suffering any fan of the retro games on PI; I experienced the same problem a few years ago when I road tested a previous model of the Raspberry Pi just here (maybe 2016?) But the fan, better than me, count on a lot of forums pointing the right way to solve these problems.
    Enrico
    • Vote Up +6 Vote Down
  • ntewinkel
    I just watched your videos this morning on YouTube, Doug image
    Looks like a very nice unit, with some pretty solid looking parts. Thanks for stepping us through the process.
    I was a little disappointed to see that the kit didn't come with a pre-built ready-to-go SD card, as that would have removed all the hours of fiddling around configuring it all.
    Cheers,
    -Nico
    balearicdynamics over 7 years ago in reply to dougw
    Do you mean just games or the entire Amiga software? I have tried to install some Amiga games but I was unluunluckyck and the ones I downloaded are not working with the emulator (Mame).
    Enrico
