Raspberry Pi
Raspberry Pi
Blog Raspberry Pi LIPO battery Pack Endurance Test
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: Problemchild
  • Date Created: 1 Jan 2015 4:05 AM Date Created
  • Views 3172 views
  • Comments 11 comments
  • endurance
  • battery_pack
  • battery
  • raspberrypi
  • lipo
Problemchild
Problemchild
1 Jan 2015
It seems to be a regular question "how long will my Raspberry Pi last with battery XYZ?", obviously the answer is "it depends" but really what kind of answer is that.
To give an indicative answer I decided to try it for my self with a standard Raspberry Pi model B and a 10Ah LIPO Battery Pack from Seeedstudio
Nothing fancy here just the RPI in near idle state running a clock to allow the time lapse camera to keep track of the elapsed time.
The raspberry Pi was running at around 350ma which I thought was quite low but maybe the latest Rasbian 24/12/14 has some power management foo included, also the network  wasn't in use and this can be a bit of a power hog.
Any way the final result was very nearly 17 Hours which I think is quite impressive ...what do you think?
  • Problemchild
    Problemchild over 11 years ago in reply to larisbird +1
    I'm glad you liked it, have you tried the display direct form 5V it may work but the back light could conceivably have trouble?! A 12V pack with a 5V buck regulator will probably be more efficient, maybe…
  • Problemchild
    Took a look, really less than obvious how you would proceed with that. As you said previously it would be much easier and more likely to continue to work afterwards if you used a boost converter to get…
  • rew
    rew over 11 years ago +1
    John, The battery pack is rated at 10Ah at 3.7V. That would mean it should be able to provide 10/5*3.7 = 7.4Ah at 5V, assuming 100% conversion efficiency. With the pi running at 350mA you should in theory…
  • Problemchild
    Took a look, really less than obvious how you would proceed with that. As you said previously it would be much easier and more likely to continue to work afterwards if you used a boost converter to get the required 12V. One of these may well do the job..... Don't believe the 4Amp rating and  I would be happy with 1 which should be enough for your display !
  • larisbird
    larisbird over 11 years ago in reply to Problemchild
    I had to post it on the original thread,  I couldn't insert the image in a reply.
  • Problemchild
    The image didnt come through Jack ...can you resend?
  • larisbird
    Not sure if you got my email
    It won't power on with 5V....I've read that you can modify the board to accept 5 instead of 12 but I've never done anything like that before.
    Would you mind looking at the board and giving me your thoughts?
  • Problemchild
    A 12V pack with a 5V buck regulator will probably be more efficient, maybe cheaper as well. Step down regulator modules are more common, cheaper and efficient.
    By the looks most of the power draw will be the monitor so this is the one to have the least conversion steps involved.
