Raspberry Pi
Raspberry Pi
Blog Setting up an Xfce Desktop Environment on Pi
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 25 Mar 2015 12:55 PM Date Created
  • Views 9929 views
  • Comments 8 comments
  • pi
  • lightdm
  • raspberry_pi_2
  • raspberry_pi_space
  • xfce
e14 Contributor
e14 Contributor
25 Mar 2015
This technote covers setting up the Xfce desktop environment and session manager on a Raspberry Pi.  Folks who use a Linux distribution that make use of Xfce will find the Raspbian Xfce quite familiar.  I find that the look and feel of the desktop and the application menu organization is almost identical to that of Xubuntu which I use at home on Mini-ITX builds.
The latest Raspbian image (2015-02-16) from http://www.raspberrypi.org/downloads/ includes Openbox and LXDE as desktop environment options on top of LightDM.  Xfce also uses LightDM so I was not surprised that Xfce installed so easily and was immediately available for use without any “tweaks”.
Note that one can also install the MATE desktop session manager that Linux Mint users are quite familiar with.  Maybe other desktop session managers too although the gating factor would be that they should interoperate with LightDM in order to avoid a lot of re-tooling.
Start with the following and go have a snack or walk the dog while its running:
sudo apt-get -y install xfce4 xfce4-screenshooter
This installs the desktop environment and session manager, the related applications, and a screen-shot application that is the best that I have ever used [(-:].
To try out Xfce once,
    • Logout.
    • At the login prompt, select “Xfce Session” in place of “Default Xsession”.
    • Login.
Note that the next time that you reboot/logout and come back, you will be back to whatever desktop session manager that you were using before.  To make use of Xfce from now on as the default, execute the following:
sudo update-alternatives --config x-session-manager
This will bring up a menu that should look like the following (or similar, depending on what you have been tinkering with):
   Selection    Path                      Priority   Status
  0            /usr/bin/startlxde-pi      90        auto mode
  1            /usr/bin/lxsession         49        manual mode
  2            /usr/bin/openbox-session   40        manual mode
  3            /usr/bin/startlxde         50        manual mode
  4            /usr/bin/startlxde-pi      90        manual mode
  5            /usr/bin/startXfce4        50        manual mode
  6            /usr/bin/Xfce4-session     40        manual mode
Assuming your #6 looks like the above, select 6 to make Xfce the default session from now on.
Reboot.  That's it!  Feel free to comment or mail me if you have issues with installing or using Xfce.
    e14 Contributor over 10 years ago in reply to e14 Contributor +2
    1. Enable auto-login to XFCE environment cd /etc/lightdm sudo your-favorite-editor lightdm.conf Ensure that the [SeatDefaults] section looks like this: [SeatDefaults] autologin-guest=false autologin-user…
    e14 Contributor over 11 years ago in reply to clem57 +1
    Hah! You said the "W" word, not me. (-: My concerns will be, as a former corporate victim: desktop security, performance, and reliability. I suspect that M$ has missed the SoC boat and/or they are trapped…
    e14 Contributor over 8 years ago in reply to mp2100 +1
    Thank you for the syntax corrections. It's hard getting around the 1GB RAM issue. But, I have found improved performance by using an external USB disk for boot as well as operations. I no longer have an…
  • clem57
    clem57 over 11 years ago in reply to e14 Contributor
    Or Windoze! Beginning to see a light and it is Linux.
    Thanks, Clem.
    I also find Xfce to be more convenient to amend than Openbox and Lxde.  E.g. with reference to the supplied image of my Pi Xfce desktop, all of the icons on the top panel were dragged there from the menu tree.  No need to edit configuration files.
    I'll probably get some comments from the Lubuntu folks and others here.  POSIX systems have so many different ways to individualize, mix, and match; that is their true beauty.  Much better than the "one way" ideologies.
  • clem57
    A good way to get a different look and feel. Thanks for the blog
    Clem
