Raspberry Pi
Raspberry Pi
Blog Wio RP2040 mini Dev Board
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: ralphjy
  • Date Created: 11 Feb 2022 4:19 AM Date Created
  • Views 9275 views
  • Likes 11 likes
  • Comments 11 comments
  • mqtt
  • seeed_wio_rp2040_wifi
  • arduino ide
  • rp2040
ralphjy
ralphjy
11 Feb 2022
The Raspberry Pi RP2040 MCU has become ubiquitous in the IoT world.  It seems like most manufacturers have their own dev board variations.
I have been looking for a low cost version with rf connectivity that I could integrate into my projects.
I came across an offering from Seeed Studio that is a small low cost ($6.95) PCB module with castellated pads that integrates an RP2040 with an ESP8285 WiFi chip: Wio RP2040 Module.
  • Powerful CPU: dual-core 133MHZ RP2040 processor and 264KB SRAM, 2MB Flash
  • Reliable wireless connection: using powerful ESP8285 WiFi chip, supporting 2.4~2.4835 GHz frequency and AP&Station mode
  • Flexibility: compatible with Thonny editor
  • Extremely compact size: 18.0x 28.2x 1.0mm 32 pins SMT
  • Multiple certifications: FCC and CE Certified
I wanted to try out the module, but to make testing easier I decided to get a mini dev board that incorporates the module and adds the convenience of buttons, LEDs,  power regulator, and a USB-C connector: Wio RP2040 mini Dev Board for $12.95.  The only inconvenient issue is the board width is not very breadboard friendly.
Lots of examples are using MicroPython, but I prefer C and Seeed has Arduino board libraries for the RP2040 - so I decided to use the Arduino IDE.
I wrote a quick program to test it out.  It just measures the RP2040 core temperature and publishes it over MQTT.  It also subscribes to the temperature and prints it over the Serial Monitor to verify the callback operation.
Wio_RP2040_MQTT.ino
#include "seeed_rp2040_wifi.h"
#include "arduino_secrets.h"
WiFiMqtt mqtt_test;
float tempRP2040 = 0.0;
void mqtt_cb(const char *topic, const char *msg)
  Serial.println();
  Serial.print("Subscribed topics:");
  Serial.println(topic);
  Serial.print("Received message:");
  Serial.println(msg);
  Serial.println();
void setup()
    Serial.begin(115200);
    while (!Serial);
    delay(2000);
    Serial.println("******start*******");
    while(false == WiFi.begin(SECRET_SSID, SECRET_PASS))
         Serial.println("connect wifi fail ,try again");
         delay(5000);
    Serial.println("success connect wifi");
    //set
    mqtt_test.mqtt_setcfg("Wio_RP2040","","",0,0,"");//client_id,username,password,cert_key_ID,CA_ID,path
    //connect
    while(!mqtt_test.mqtt_connect("10.0.0.234",1883,0));//server,port,reconnect
    mqtt_test.mqtt_set_callback(*mqtt_cb);
    mqtt_test.mqtt_subscribe("wio_rp2040/temperature",0);
void loop()
  //read core temperature
  Serial.printf("Core temperature: %2.2fC\n", analogReadTemp());
  tempRP2040 = analogReadTemp();
  char tempString[8];
  dtostrf(tempRP2040, 1, 2, tempString);
  //publish
  mqtt_test.mqtt_publish("wio_rp2040/temperature",tempString,0,0);//topic,data,qos,retain
  mqtt_test.mqtt_check_msg();
  delay(1000);
And the plot on my MQTT server
I think that I'll get some modules to try on custom PCBs.  Just have to think of some projects to do...
  • ralphjy
    ralphjy over 4 years ago in reply to mp2100 +1
    If you don't want to pay an expedited cost, the America Direct Line is 15-20 working days. One of the bigger issues is availability of product. I got this particular board from Mouser for the same price…
  • ralphjy
    Also, not sure if you know that Seeed has a US warehouse, but it usually only carries the most popular products - sometimes you can get lucky and save time and money.  It shows as an option on the product page when it is available.
  • ralphjy
    One of the bigger issues is availability of product.  I got this particular board from Mouser for the same price and it took 3 days.
    There are a lot of parts in the distribution chain - it is often easier to find parts at Digikey and Mouser than from the manufacturer (Seeed, Adafruit, Sparkfun, etc).
    dougw over 4 years ago in reply to shabaz
    UDOO KEY combines RP2040 with a Pi Pico footprint and an ESP32.
    $4 right now (pre-release) but going to $18 after release.
  • mp2100
    mp2100 over 4 years ago
    That's a good price for what's included.  How is the shipping time from Seeed these days?
  • ralphjy
    ralphjy over 4 years ago in reply to shabaz
    That's an interesting suggestion.  I have to admit that even though I bought 5 Picos when they first came out - I haven't used one in a semi-permanent project (i.e. hardwired).
    I've noticed that there are a lot of castellated modules using the RP2040 becoming available which will make it a lot easier for makers like me to customize projects Slight smile.   I guess I should really try a PCB assembly service like the rest of you do...  then I could use BGAs directly.
