Raspberry Pi Forum What do you want to do/see done on the pi 4?
  • Replies 17 replies
  • Subscribers 686 subscribers
  • Views 2029 views
  • project ideas
  • raspberry pi 4 project ideas
  • raspberry pi 4
  • raspberry pi
gam3t3ch
gam3t3ch over 6 years ago
I am having so much fun with the Pi 4 as my desktop and finding alternatives and different things to do with it is such an easy task.
I thought I would see what other people would like to either do with a pi 4 or see done with it.
Personally I have it setup as a little studio which is working great.  I am running the following
Raspberry Pi 4 (2GB) with 5v fan
Single monitor with built in speakers viewsonic – vs11444
Logtech 920 Webcam
Behringer Xenyx Q502 USB / Neewer NW – 700
USB Powered 2.0 Hub (7port)
External SSD Drive as main boot drive Kingston 120gb
Testing power consumption over a 1 month period Leaving the unit powered on the whole time and only using powered mixer when recording only but will be plugged in for the start of the test.
I still need to run some better speakers for doing some music editing which will be coming shortly into the mix as well.
That is my current setup and have plans for more with it as it seems to be preforming better then I had expected.  Will have to get the 4gb version soon as well.
So with that all being said who else is using the pi4 as a desktop?
And have you replaced your desktop yet completely?
What kind of projects or ideas would you suggest for making the pi desktop better?
What would you do or want to see be done with the pi 4?
  • clem57
    clem57 over 6 years ago in reply to neuromodulator
    I believe it is more of exploring the way waves on GNUradio reflect and modulate especially at night. Maybe something else. But I see a wealth of things to learn and play with.
    That is my opinion of course. neuromodulator any comments of your usage?
  • neuromodulator
    neuromodulator over 6 years ago in reply to clem57
    Sorry, I got lost on what you were referring in your comment. Sean apparently had GNUradio suck all his computational resources when demodulating FM, that's what I found surprising.
    Now on the usage I was referring to downloading NOAA or GOES sat images. NOAA sats transmit images around 137 Mhz and a DIY antenna can be built without investing much money on it. GOES sats transmit at around 1680 Mhz, are stationary and their images are of very high resolution, the rig is more expensive too, it requires a parabolic antenna, some filtering and some LNAs, but the images are just amazing. Here is a nice link: https://www.rtl-sdr.com/rtl-sdr-com-goes-16-17-and-gk-2a-weather-satellite-reception-comprehensive-tutorial/
  • gam3t3ch
    gam3t3ch over 6 years ago in reply to neuromodulator
    I tried weather sat images on the pi2 a while back it worked well but certainly could have been better might be something to revisit on the pi4 for sure.
  • clem57
    I like that project... Thanks neuromodulator
  • Problemchild
    Problemchild over 6 years ago in reply to neuromodulator
    Probably maxed out the memory just loading it in the FM decoding was the least of the problems....
    Also running in GRC no doubt burnt more resources!
    I would also like to know if the GNU Radio install for the PI is just a lift and shift or have they made an effort to use VOLK and all the optimised math libs??
  • Problemchild
    Problemchild over 6 years ago in reply to gam3t3ch
    How well did that work on the older PI on a PC it works fine?!
  • Problemchild
    All depends on whether he was trying APT or LRIT/HRIT which are much more detailed
