Raspberry Pi Forum Avnet SmartEdge IoT Gateway - cgroup memory
  • Replies 12 replies
  • Subscribers 704 subscribers
  • Views 2789 views
  • avnet smartedge iot gateway
stopje
stopje over 6 years ago
On avnet Raspbian system (as delivered with IoT gateway) I have hard time to enable cgroup memory.
I added to cgroup_enable=memory cgroup_memory=1 /boot/cmdline.txt with no effect.
Is there any special trick needed?
  • clem57
    clem57 over 6 years ago
    It depends on what release you have stopje . https://github.com/raspberrypi/linux/commit/ba742b52e5099b3ed964e78f227dc96460b5cdc0  explains the confusion. Please post the release from:
    uname -a
  • stopje
    stopje over 6 years ago in reply to clem57
    uname -a gives:
    Linux raspberrypi 4.14.79-v7+ #91 SMP Tue Jul 16 05:42:32 PDT 2019 armv7l GNU/Linux
    I used both  cgroup_enable=memory  and  cgroup_memory=1 but unfortunatelly  it still didn't work. Might it be related to some avnet modifications?
  • clem57
    clem57 over 6 years ago in reply to stopje
    Here is all the details cgroups(7) - Linux manual page .
    • the availability  of the cgroups feature is governed by the CONFIG_CGROUPS kernel con‐
      figuration option. So maybe it was not built with this!
    • Linux cgroup started version 2 in Linux 4.5. Since you are not there yet, an upgrade or newer version may help.
    • Check docker for which you need. Version 1 may be OK! Or not.
    • Can you use standard Rasbian?
  • clem57
    clem57 over 6 years ago in reply to clem57
    https://medium.com/@kasunmaduraeng/docker-namespace-and-cgroups-dece27c209c7  A good read...
    systemd-cgls <== to check if used and available
  • stopje
    Thank you,
    I cannot use standard Raspbian directly as Avnet added some extra layers. Will try to modify their build.
    It is not for docker but for AWS IoT greengrass. I use it on other devices and now I am playing with the Avnet SmartEdge IoT Gateway.
  • clem57
    Oh I never heard of greengrass until now. But in looking at an overview, I found this statement for 1.10:
    A new Greengrass Docker application deployment connector that runs a Docker application on a core device. For more information, see Docker Application Deployment Connector.
    That reference implies usage of docker under the covers.
  • stopje
    Greengrass is great technology, anyway it is independent from docker but they released version that can be run inside container as well.
  • stopje
    I found interesting thing.
    my cmdline.txt look like this:
    cat /boot/cmdline.txt
    dwc_otg.lpm_enable=0 console=tty1 rootfstype=ext4 rootwait console=serial0,115200 root=/dev/mmcblk0p2 fsck.repair=yes cgroup_enable=memory cgroup_memory=1 elevator=deadline
    but
    dmesg | grep Kernel
    shows:
    [    0.000000] Kernel command line: dwc_otg.lpm_enable=0 console=tty1 rootfstype=ext4 rootwait root=/dev/mmcblk0p2 fsck.repair=yes elevator=deadline
    I am confused. From where is it coming?
  • clem57
    stopje
    Well, I think I found the problem: the one who parses cmdline.txt does not like empty lines before the valid cmdline: I have that:
    # comment
    # <previous cmmdline line commented out>
    # comment
    <new cmdline>
    changing it to:
    # comment
    # comment
    <new cmdline>
    makes it work.
    Be careful of newline characters as they are trouble too.
    Also it is /boot/cmdline.txt.
    So, I would test things by adding
    disable_splash=1
    and looking at
    dmesg | grep Kernel
    like before. This will stop the multi color splash screen...
    Clem
  • stopje
    clem57 my cmdline.txt is absolutely one liner. Single space between entries. I stumbled upon the other post
    But mistery is solved. They use custom bootloader https://github.com/Avnet/smartedge-iiot-gateway-uboot
    and treadme states:
    Note:
    We do not process cmdline.txt so if you need to change it then edit .config file entry BOOTCOMMAND=.
    So now I need to follow their instruction and hopefully it will work.
    Thanks for guidance on other steps.
    BR,
    Jerzy
