Raspberry Pi Forum encoder dc motor position control with raspberry pi
  • Subscribers 704 subscribers
  • Views 2763 views
  • position control
  • dc-motor
  • raspberrypi
enesss
enesss over 6 years ago
Hello.
I have to pid control of the encoder motor position with rasberyy pi. but i don't know how to do it. Requested in the project: If the user enters 10 degrees, the engine will turn 10 degrees and stay there. then it will go to 200 degrees if it enters 200 degrees.  I need your help in this regard.
    michaelkellett over 6 years ago
    This sounds like a homework question - please correct me if I'm wrong.
    You need to describe the hardware a bit better, what kind of motor, how is it controlled by the PI. What kind of position encoder - how is it interfaced to the Pi.
    Do you understand the basis of PID control ?
    If you fill in these details it may be possible to help you better.
    The web is full of stuff about PID motor control, try this for a start:
    https://projects.raspberrypi.org/en/projects/robotPID
  • enesss
    enesss over 6 years ago in reply to michaelkellett
    this is a part of my graduate thesis..
    motor: https://www.pololu.com/product/4754
    motor driver: L298N
    I have to use raspberry pi. i can not use arduino.
    I do not know PID control and i have only 2 days for finishing this project. image please help.
    michaelkellett over 6 years ago in reply to enesss
    Sorry - no.
    What value is a graduate degree if your thesis is written by some one else ?
  • enesss
    I will realize this project and move on to the next step. but I'm stuck here. so it's just part of my thesis. I am a university student and I am aware of my responsibilities. nobody will  write my thesis.I just need a little help. thanks.
  • gargayakho
    gargayakho over 5 years ago
    I have the same problem, I would like to know if it solved it.
    I am not sure how to perform the calculation so that it works with PWM.
