Raspberry Pi Forum Raspberry Pi doesn't work with vnc...
  • Subscribers 701 subscribers
  • Views 3289 views
  • raspberry_pi_space
aman5209
aman5209 over 5 years ago
When I try to connect my raspberry Pi 4 with vnc viewer then I always get request tym out. In starting it works well with vnc viewer but now it doesn't work I don't know what to do... someone help me ....I also attached a photo in which I Run a command ie; ping raspberrypi.mshome.net on terminal and get this....
Thanks in advance..
  • koudelad
    koudelad over 5 years ago
    you haven't accidentally included the photo yet.
    Have a look at this help article by RealVNC:https://help.realvnc.com/hc/en-us/articles/360002249917-VNC-Connect-and-Raspberry-Pi#running-directly-rendered-apps-such-as-minecraft-remotely-0-2 https://help.realvnc.com/hc/en-us/articles/360002249917-VNC-Connect-and-Raspberry-Pi#running-directly-rendered-apps-such…
    I suppose you want to connect remotely to a Pi , so you will use the preinstalled server (or install it as explained above).
    Determine the IP of the Pi (as reported by the VNC server), and try to connect to it from a PC or another device using a RealVNC client. This is all you need in your local (home) network - LAN.
    If the connection was not successful, make sure you are in the same network or have properly configured firewall and/or a network router (or port forwarding in case you are connecting over the internet).
    David
