Raspberry Pi Forum AVNET SmartEdge IIOT Gateway: can't get FullHD(1920x1080p) display content for X11
  • Subscribers 703 subscribers
  • Views 1236 views
  • iiot
  • fullhd
  • smartedge
  • display
  • iiot gateway
  • 1920x1080
billounet
billounet over 5 years ago
Hi All,
I'm facing a major issue as I'm not able to display x11 in full screen when connecting a FullHD (1920x1080) display panel on the HDMI port off the AVNET SmartEdge IIOT Gateway.
I'm using the latest runtime image from avnet generated on 2020 March 26 (from here).
I have run only those commands, to install X11 server and chromium.
# Ensure Avnet /boot files don't change with upgrade
sudo apt-mark hold raspberrypi-bootloader
sudo apt-mark hold raspberrypi-kernel
sudo apt-mark hold raspberrypi-sys-mods
# Get latest updates
sudo apt update
sudo apt upgrade -y
sudo apt dist-upgrade -y
# remove pre-installed softwares
apt-get remove -y --purge scratch squeak-plugins-scratch squeak-vm python-minecraftpi minecraft-pi sonic-pi oracle-java8-jdk bluej greenfoot libreoffice-common libreoffice-core freepats nodejs
apt-get autoremove -y
# install minimal set for x11 and chromium
apt-get --assume-yes install --no-install-recommends xserver-xorg x11-xserver-utils xinit openbox
apt-get --assume-yes install --no-install-recommends raspberrypi-ui-mods
apt-get --assume-yes install --no-install-recommends lightdm
apt-get --assume-yes install --no-install-recommends chromium-browser
I have set the screen resolution in the config.txt with :
hdmi_group=2
hdmi_mode=82
The display panel is reporting the right resolution, but the content (Xorg session) is not full screen.
The fbset command reports a strange resolution of 1824x984 instead of 1920x1080. So I have modified the /etc/fb.modes file and added :
mode "1920x1080-60"
    # D: 148.500 MHz, H: 67.500 kHz, V: 60.000 Hz
    geometry 1920 1080 1920 1080 32
    timings 6734 148 88 36 4 44 5
    hsync high
    vsync high
    accel true
    rgba 8/0,8/8,8/16,8/24
endmode
But this does not help. So does someone have been able to run content in full screen on that platform ?
If yes, then what is the magic configuration !
  • billounet
    Hi Avnet and Element14,
    I have tried the latest runtime image from you delivered on Feb 2021, and I'm still not able to get the content displayed correctly on my screen. I have tested with 4 different screens from 4 different manufacturers and the problem still exist.
    Is someone able to perform the exact operation that I have done on its device and tell me what I'm doing wrong ?
    Steps :
    1/ Update the platform using the latest runtime image
    2/ Create a ssh file in the /boot folder to enable ssh
    3/ Connect remotely to the target and run commands as root :
    apt update
    apt upgrade -y
    apt dist-upgrade -y
    # Install Xorg and lightdm
    apt --assume-yes install --no-install-recommends xserver-xorg raspberrypi-ui-mods lightdm
    4/ Edit the /boot/config to set the screen resolution
    hdmi_group=2
    hdmi_mode=82
    5/ Reboot
  • billounet
    The solution is to skip Uboot during the boot process in order to get the correct display content.
    Just modify /boot/config.txt:
    # This will boot kernel directly, skipping u-boot
    kernel=zImage
    # Uncomment the following:
    disable_overscan=1
    # Comment out the following (not needed if skipping u-boot):
    #framebuffer_swap=0
    # All other display and framebuffer settings should not be needed, comment them out as well
    Enjoy !
    Nicolas
    Jan Cumps over 5 years ago in reply to billounet
    Good catch!.
    Heads-up: except if you use the initial linux release, you don't have to mark-hold the 3 modules anymore.
    It is now part of the release and of the update script.
