Raspberry Pi Forum Trafic light
  • Replies 7 replies
  • Subscribers 705 subscribers
  • Views 1778 views
  • rasberry_pi_3_b_plus
Trafic light
alcor48
alcor48 over 5 years ago
I got that code from issue 104 of MagicPi
It's made for RBp Pico (micro python). But I want to do it on Raspberry Pi 3b+
It already bug at import machine. As such linbrary/module does not exist. Can someone help make it work.
import machine
import utime
import _thread
led_red = machine.Pin(15, machine.Pin.OUT)
led_amber = machine.Pin(14, machine.Pin.OUT)
led_green = machine.Pin(13, machine.Pin.OUT)
button = machine.Pin(16, machine.Pin.IN, machine.Pin.
PULL_DOWN)
buzzer = machine.Pin(12, machine.Pin.OUT)
global button_pressed
button_pressed = False
def button_reader_thread():
while True:
if button.value() == 1:
button_pressed = True
utime.sleep(0.01)
_thread.start_new_thread(button_reader_thread, ())
while True:
if button_pressed == True:
led_red.value(1)
for i in range(10):
buzzer.value(1)
utime.sleep(0.2)
buzzer.value(0)
utime.sleep(0.2)
led_red.value(1)
utime.sleep(5)
led_amber.value(1)
utime.sleep(2)
led_red.value(0)
led_amber.value(0)
led_green.value(1)
utime.sleep(5)
led_green.value(0)
led_amber.value(1)
utime.sleep(5)
led_amber.value(0)
traffic_light_controller.py
  • nathandumont
    nathandumont over 5 years ago
    The "machine" library is a special feature of MicroPython, it wraps up all the hardware nitty-gritty and gives a standard way to access physical I/O like pins.
    There doesn't seem to be a nice "machine" library available for CPython (the version of Python you'll find on the Pi 3 and other Linux computers), at least not yet.
    To get this to run on a Raspberry Pi 3 running Linux, you'll need to switch out the "machine" library and instead use another GPIO library.  There are several to choose from, I think the one that best fits the syntax in this example is gpiozero: https://gpiozero.readthedocs.io/en/stable/
    Do you know what pins you're going to connect the inputs and outputs to?
  • alcor48
    alcor48 over 5 years ago in reply to nathandumont
    Merci Nathan,
    Yes I know the pin out, I think I was able to convert these out.
  • hugohu
    hugohu over 5 years ago
    Can you send me a wiring diagram? and preferably some images of the leds?
    I'd assume it's just 3 leds with resistors connected to GPIO.
  • alcor48
    alcor48 over 5 years ago in reply to hugohu
    Here is the whole project link. It's 3 leds, a switch and a buzzer.
    The MagPi issue 104 — The MagPi magazine (raspberrypi.org)
    Download the magazine. Then it's on page. 58. Pico Traffic light controller.
    Thanks.
  • beacon_dave
    beacon_dave over 5 years ago
    There is a traffic light example in the Essentials GPIOZero book, using Python which may be of use.
    https://www.raspberrypi.org/magpi-issues/Essentials_GPIOZero_v1.pdf
  • hugohu
    hugohu over 5 years ago in reply to beacon_dave
    ha, you beat me!
  • beacon_dave
    beacon_dave over 5 years ago in reply to beacon_dave
    Another guide for Python here:
    https://github.com/raspberrypilearning/jam-worksheets/raw/master/pdf/Traffic-Lights-Python.pdf
    linked from:
    https://projects.raspberrypi.org/en/projects/traffic-lights-python
    Also may be of interest:
    Product LinkProduct Link PI Stop educational traffic light for Raspberry Pi
    Product LinkProduct Link Traffic Shield for Raspberry Pi
