Raspberry Pi Forum RasClock Module with cirrus audio logic
  • Subscribers 704 subscribers
  • Views 335 views
  • raspeberry_pi_accessories
Hi guys, is there a way to use the RasClock Module with the cirrus audio logic card?
If so, is there a 2nd 3,3V pin to use for other things?
    shabaz over 10 years ago
    If you can figure a way to get them connected to the header in parallel, then yes they will likely work but you'll have to try it to be sure and then report back.
    The reason why it will likely work is because you can see by examining what pins are shared between the two boards. If it is just the power supply rails and the I2C bus pins (SDA and SCL)
    and the functions are different then usually you're fine (for all the detail you could want on this topic, check out the I2C spec or the I2C guide on wikipedia).
