Raspberry Pi Forum Cirrus Audio Card and Jasper
  • Subscribers 704 subscribers
  • Views 362 views
  • wolfson_audio_card
  • jasper
  • audio
  • wolfson_pi
  • cirrus
  • cirrus_logic_audio_card
  • raspeberry_pi_accessories
  • wolfson/cirrus
Has anyone got Jasper working with the cirrus logic audio card and a raspberry pi 2? I am trying to use spkout speakers and the DCIM microphones with Jasper.
I manually installed Jasper ontop of the cirrus audio card image as per the instructions from Jaspers website. The image was working fine before the install of Jasper.
I have replaced the asoundrc file with the one built by ragnar.jensen in this post http://www.element14.com/community/roadTestReviews/1810. However I am pretty sure this is meant for the original woflson audio card and the raspberry pi b.
When running jasper I get the welcome audio message played out through the raspberry pi headphone jack and then it fails with this error:
No handlers could be found for logger "cmuclmtk"
*             JASPER - THE TALKING COMPUTER           *
* (c) 2015 Shubhro Saha, Charlie Marsh & Jan Holthuis *
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
ALSA lib pcm_dsnoop.c:612:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm_direct.c:877:(snd1_pcm_direct_initialize_slave) slave plugin does not support mmap interleaved or mmap noninterleaved access
ALSA lib pcm_dmix.c:1030:(snd_pcm_dmix_open) unable to initialize slave
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
ALSA lib pcm_dsnoop.c:551:(snd_pcm_dsnoop_open) The dsnoop plugin supports only capture stream
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
Traceback (most recent call last):
  File "/home/pi/jasper/jasper.py", line 148, in <module>
    app.run()
  File "/home/pi/jasper/jasper.py", line 118, in run
    conversation.handleForever()
  File "/home/pi/jasper/client/conversation.py", line 31, in handleForever
    threshold, transcribed = self.mic.passiveListen(self.persona)
  File "/home/pi/jasper/client/mic.py", line 110, in passiveListen
    frames_per_buffer=CHUNK)
  File "/usr/lib/pymodules/python2.7/pyaudio.py", line 714, in open
    stream = Stream(self, *args, **kwargs)
  File "/usr/lib/pymodules/python2.7/pyaudio.py", line 396, in __init__
    self._stream = pa.open(**arguments)
IOError: [Errno Invalid input device (no default output device)] -9996
Note I can now not get the cirrus audio card to record or play files using the usual aplay and a record commands.
Any thoughts / comments / help would be hugely appreciated.
Tom
