Raspberry Pi Forum Spidev problems in xfer2()
  • Subscribers 706 subscribers
  • Views 4087 views
  • python;
  • raspberypi
  • spidev
  I am trying to use the spi bus from Python on my Raspberry pi 2 model B and my python script just stops when I try to do an xfer2.
Background:
  I have an MCP3008 hooked up to the spi bus
  When I do an  ls /dev  I see both spidev0.0 and spidev 0.1 so I know the bus is enabled.
  I have used the C spi bus loopback test that is out on the web and it runs successfully.
  I have installed the python wrapper for spidev.
  I am running Python 3
To debug the problem I simplified the code to the following (it is in a file called spi_testcode.py)
import sys
import spidev
print('Starting test code')
adc_channel = 7
print('initializing the spi bus instance')
spi_bus = spidev.SpiDev()
print('opening the spi bus')
spi_bus.open(0, 0)
print('getting the adc output ')
adc_output = spi_bus.xfer2(1, 8 + adc_channel << 4, 0 )
print('adc read complete')
The following is what happens when I run the code:
pi@raspberrypi: ~ software $sudo python3 spi_testcode.py
starting test code
opening the spi bus
Notice that final print statement of the program is never executed.  The program exits during the xfer2() call with no error message or warning.   Consequently it is hard to figure out what to do to debug this....  any suggestions?
  • clem57
    clem57 over 10 years ago
    Can you check the return codes? Maybe the spi bus is not opening and then your xfer2 hangs.
    Clem
    e14 Contributor over 10 years ago in reply to clem57
    Clem,
    I am a newbe so forgive a basic question:  How do I check the return codes?
    I tried this:
        import sys
        import spidev
        print('initializing the SPI bus instance')
        spi_bus = spidev.Spider()
        exit_code = spi_bus.open(0, 0)
        print ("exit code from open is", exit_code )
        adc_output = spi_bus.xfer2(1, 240, 0 )
    When I run it I get:
        pi@raspberrypi:~/Software $ sudo python3 spi_testcode.py
        Starting test code
        opening the spi bus
        exit code from open is None
    The exit code of the open() was 'None'.  In python I believe that means there was no exit code.   Is there another way to check?
  • clem57
    clem57 over 10 years ago in reply to e14 Contributor
    import spidev
    import time
    spi = spidev.SpiDev()
    spi.open(0,0)
    while True:
       resp = spi.xfer2([0x00])
       print resp[0]
       time.sleep(1)
    I googled this from https://www.raspberrypi.org/forums/viewtopic.php?f=44&t=56669
    See how after the open, A truth statement will not execute unles Sspi.open works? I have not tried this, but it expresses the intent. Reading furtherer they say a permission problem. You may not be running this with root permission. On the raspberry Pi you cannot as a plain user affect the hardware. Linux tries to allow only root or users with root permissions(sudo) to do hardware things.
    Clem
    Clem,
      I don't see how the 'while True' could be affected by the previous open() statement.  'True' is a python keyword that is always 'true'
    However,  you still helped tremendously!!!  I tried the code in your reply and things started running more or less as you would expect... I got a print statement every second.   That tells me it was getting through the xfer2() code.    Hmmmmmm..... a clue!!!
    I looked closely at the code you suggested and noticed it was only passing one hex byte in brackets to xfer2():  xfer2([0x00])
    My code was passing 3 decimal bytes without brackets:
    xfer2(1,240,0)
    After playing with different combinations I discovered the brackets made the difference.  The following seems to work:
    xfer2([1,240,0])
    So.... xfer2() is looking for a list and I was passing 3 separate variables.
    Now the embarrassing thing:   The code examples on the web that I was copying had the brackets!!   I visually compared my code to the examples several time but never noticed that difference..... :-(.
    I caused the problem but it is too bad the spidev code did not flag the error better
    Problem solved.... now I am able to move forward with the build.
    Thanks!!
  • clem57
    Glad to help you realize the situation. Please help me get points by marking this answer as correct
    Clem
    PS here is why:
    Anything in a bracket in Python is a list of items. Without the list means more parameters which the wrapper cannot expect. The bracketed list is just one parameter.
