Raspberry Pi Forum All Testing passed
  • Replies 48 replies
  • Subscribers 716 subscribers
  • Views 6012 views
  • raspberry
  • pi
All Testing passed
See   http://www.raspberrypi.org/  to see the good news
  • fustini
    fustini over 14 years ago in reply to e14 Contributor
    Interesting, I notice that too now that you point it out.
    BTW, when doing a check of the RPi.org blog comments just now, I noticed someone posted a link to this episode of the EEVBlog which tours a test chamber:
    I must applaud the inclusion of the multiple certifications for Europe and North America.  At least this will alleviate any possible delays based on testing.
    I am curious as to what the "Canadian thing" was that had to be tested?
  • Ellis
    Ellis over 14 years ago in reply to e14 Contributor
    If you look at the Dell regulatory statement you will see that they use the same description.
    Kevin,
    I'm not as confident as you seem to be that the testing done so far will
    "alleviate any possible delays based on testing".
    The FCC rules, Title 47, section 15.3 "Definitions", paragraph i, say:
    "Class B digital device.   A digital device that is marketed for use in a
    residential environment, notwithstanding use in commercial, business
    and industrial environments.  Examples of such devices include, but
    are not limited to, personal computers, calculators, and similar
    electronic devices that are marketed for use by the general public."
    But apparently, Class B testing has not been done, even though the
    RPi is being marketed as a PC for use in residential environments.
    There is another section, 15.32 "Test procedures for CPU boards
    and computer power supplies",  but it doesn't seem to have been
    followed, from what we know.  It refers to testing within an enclosure
    with the cover removed.
  • rew
    rew over 14 years ago in reply to e14 Contributor
    It's the Canadian equivalent of the FCC and CE marks. Someone forgot what it was called while typing a blog post or something and from there on in the "raspberry pi community" this phrase has stuck. Consider it an inside joke if you will.
    Here is an update regarding CE mark compliance: http://www.electrocomponents.com/media/press-releases/2012/04/10th/
  • rhughes-uk
    rhughes-uk over 14 years ago in reply to e14 Contributor
    Thanks for that most useful link. Great news hopefully.
    I am sure looking forward to tasting my RaspberryPi image
    jbeale,
      good find!
    There are some odd things in that press release.
    The first paragraph mentions that it is designed for children and IT enthusiasts
    to develop programming skills, but the second paragraph mentions "industrial or
    office environments".   It seems unlikely to find either children or IT enthusiast
    programming skill developers exclusively in industrial or office environments.
    The second paragraph mentions a warning statement to ensure that customers
    are fully aware that equipment used in a residential environment may be susceptible
    to radio interference.   I think the primary concern in residential environments is not
    susceptibility of the equipment, but interference caused by the equipment,
    which is not mentioned.
    This susceptibility warning seems to imply that it's OK to market to residential
    users with only a Class A certification, provided that a disclaimer is provided.
    I'm not sure about the EC rules, but the FCC rules apparently don't allow this.
    FCC OET Bulletin 62 (1993), which was pointed out to me on another thread,
    says, bottom of page 8:
    "If a digital device is sold or offered for sale to *any* (empasis in original) residential
    users (including commercial or industrial companies that could employ the equipment
    in a residential environment) then it is a Class B digital device regardless of its price
    or application.  Marketing through a general retail outlet or by mail order to the general
    public with a simple disclaimer, such as "For Business Use Only," is not sufficient to
    qualify for Class A."
    Page 9 also says: "Portable computers, because they are designed to be used anywhere,
    are considered Class B devices regardless of their price or restrictions placed on marketing."
    The second paragraph of the press release mentions that the boards were tested to comply
    with directive EN500081-2 (1993).  But that is an emissions standard, not a susceptibility
    standard.  We were told that susceptibility to cats was tested, were we not?  Hopefully the
    boards were also tested to a more recent emissions standard than 1993.
    Kevin,
      The Canadian EMC standard is ICES-003.
    Apparently it's very similar to the FCC requirements.
    Liz made a reply to comment on the "Testing Completed" R-Pi blog as shown below:
    liz on April 10, 2012 at 10:25 pm said:
    "Quite – a week in the testing chamber is *very* speedy, and we were only ever aiming for Class A; RS and Farnell were very clear that the board only has to be certified that far before the educational release. There’s been no “revision to easier limits”, I’m happy to say."
    I'm not a compliance specialist so I don't know all the FCC Part 15 implications.  It would be sad if the first run of boards was only available outside the US.
    On the same page, Liz also made this comment:
    liz on April 10, 2012 at 7:04 pm said:      "Happily, we’ve found it doesn’t need a shielded enclosure to reach Class B, although it will require a (very minimal) redesign."
    Now I don't know if she's referring to CE "Class B" and/or FCC "Class B" but perhaps a redesigned consumer/residential use version will be available relatively soon*, anyway.
    * well, what's a few more months, at this point?
