Raspberry Pi Forum Choosing an SD card
  • Subscribers 705 subscribers
  • Views 394 views
  • help
  • sd_card
Choosing an SD card
Somewhere I read that an SD card class 4 was required by the Raspberry Pi.  Would an SDHC Class 6 or higher class card work?  I am partial to SanDisk cards which I use with a high quality DSLR camera.
Thanks in advance
Marv
  • rew
    rew over 14 years ago
    I have sandisk extreme II and extreme III cards. To my surprise these are marked class 4 and 6. These work.
    I just got my self an "insurance" SD card: a cheap 8G class-4 card.
    There used to be an issue with class 10 SD cards. That, as far as I can tell has been resolved. It's now just that the hardware cannot use the 1.8V signalling method that class 10 cards have.
    Marv,
      preliminary SD card info is at:
    http://elinux.org/RPi_VerifiedPeripherals#SD_cards
    In some cases, a higher-end SD card may work, but not
    at full speed, because the RPi apparently can't shift down
    to the 1.8V interface.
    In some cases a higher-end SD card may not actually be faster,
    depending on whether you do I/O in small chunks or large contiguous blocks.
    Also, you may get better performance from a hard drive
    connected to a USB port.  Once the RPi is booted from the
    SD card, you can mount your filesystem from a USB drive.
    And of course be sure to get your SD card from a reputable
    source, because there are apparently lots of fake cards for sale.
