Raspberry Pi Forum How to get sound over HDMI working when using a TV?
  • Replies 58 replies
  • Subscribers 705 subscribers
  • Views 14639 views
  • raspberry
  • audio
  • hdmi;
  • hdmi
  • over
  • tv;
  • sound
  • pi;
wallarug
wallarug over 14 years ago
I have tried everything I could find on the internet but nothing has worked.  I have a HD TV and the Raspberry Pi is connect through a HDMI cable.  I have tried to change the config.txt file with hdmi_drive=2 (didn't work) and tried nothing in config.txt, I have tried sudo modprobe snd-bcm2835 as well but nothing I do seems to be working.  I installed vlc but it gives me an error: "VLC failed to initlalize your sound output device (if any).  Please update your alsa-lib to version 1.0.23-2-g8d80d5f or higher to try to fix this issue".  The help on the Raspberry Pi Forums is not very helpful...Example: "yep, got it playing videos, video games, and just plain music".  Can you please help me so that I can move on to some basic operations.  PS:  I have NO Linux knowledge so please be very specific with instructions.
  • GreenYamo
    GreenYamo over 14 years ago in reply to wallarug
    Hi Fergus,
    I was fiddling around with trying to play an MP3 at the weekend, and couldn't get it to work, until I tried the instructions on this page http://www.raspberrypi.org/phpBB3/viewtopic.php?f=28&t=4958&p=61894&hilit=alsa+mp3#p61894 second post down.
    After a re-boot, the included Debian sound player actually played my mp3 files. Didn't have much chance to test it further, as I had firmware flashing problems on another device !
    Hope this helps a bit ?
  • wallarug
    wallarug over 14 years ago in reply to GreenYamo
    I started from scratch and had no luck.  I will try and get in contact with Dom on the other forum.  I am not sure if the config.txt file is being recognised or ingnored.  So I have attached a video of my boot sequence.  Can someone let be know if something is wrong or unusual.image
    What's strange about this is that I can get full 1080p resolution when the TV is connected to my PC but not when the Raspberry Pi is connected;  this tells me that it must not be the TV causing issues but the Raspberry Pi (or software).
  • GreenYamo
    Hi Fergus, what are you trying to get sound from, that may also help also.
    Is it an mp3 file, are you playing a game etc ? The boot sequence looks OK, but it is a bit blurry to begin with and my eyes are a bit blurry anyway :-) I'm also not a Linux expert, still very much on the noob level.
    Knowing what you are trying to do may help.
    Steve
  • wallarug
    Hey Steve,
    Exactly what I am doing:
    Trying to get any sound over HDMI/through TV. As another issue: get the Raspberry Pi to register the TV as a HDMI device that supports 1080p60 (currently it is registered as a DVI device, us many know, it does not support Sound through the TV).
    If I can get 1080p @ 60Hz resolution, It may fix the sound issue as well because then the TV would be registered as a HDMI device NOT DVI.
    If that makes sense.
    Fergus
  • wallarug
    Does anyone know how to get in-touch with Dom (the broadcom expert) from the Raspberrypi Forums?  He doesn't seem to read messages on the forum.
    e14 Contributor over 14 years ago in reply to wallarug
    Fergus,
      The raspberrypi troubleshooting forum is really the best way to
    get in touch with Dom.  He doesn't participate here.  You've
    apparently tried that, but can't post there for some reason,
    possibly their spam blocker.
    Quite a few other people who have had similar difficulties posting
    have mentioned that on twitter:
    https://twitter.com/#!/Raspberry_Pi
    and Liz has solved the problem by whitelisting them.
  • wallarug
    wallarug over 14 years ago in reply to e14 Contributor
    So...How do I get in contact with Dom?
    Fergus,
      I see your posts at rpi.org are appearing, so that's progress.
    The title of the thread you posted in says "[solved]", so maybe it
    would be worthwhile to start a new thread, of course with "HDMI trouble"
    somewhere in the title, and include your edid file if possible.
    Dom Cobley works for Broadcom in Cambridge, so if nothing else works,
    you could try your luck with Broadcom's switchboard, but I would use
    that only as a last resort, since he has been quite responsive in the
    troubleshooting forum, including the thread you posted in.
  • wallarug
    Thanks coder27,
    I will start a new thread then see if I can get through to Dom.
    I don't think I will be calling-in...International rates would be too expensive and may give no luck.
  • wallarug
    wallarug over 14 years ago in reply to wallarug
    I have had a break through...I got the Raspberry Pi to register the TV as a HDMI device by adding JUST: hdmi_drive=2  To the config.txt file.
