Raspberry Pi Forum How to get sound over HDMI working when using a TV?
  • Replies 58 replies
  • Subscribers 705 subscribers
  • Views 14657 views
  • raspberry
  • audio
  • hdmi;
  • hdmi
  • over
  • tv;
  • sound
  • pi;
wallarug
wallarug over 14 years ago
I have tried everything I could find on the internet but nothing has worked.  I have a HD TV and the Raspberry Pi is connect through a HDMI cable.  I have tried to change the config.txt file with hdmi_drive=2 (didn't work) and tried nothing in config.txt, I have tried sudo modprobe snd-bcm2835 as well but nothing I do seems to be working.  I installed vlc but it gives me an error: "VLC failed to initlalize your sound output device (if any).  Please update your alsa-lib to version 1.0.23-2-g8d80d5f or higher to try to fix this issue".  The help on the Raspberry Pi Forums is not very helpful...Example: "yep, got it playing videos, video games, and just plain music".  Can you please help me so that I can move on to some basic operations.  PS:  I have NO Linux knowledge so please be very specific with instructions.
  • wallarug
    wallarug over 14 years ago in reply to e14 Contributor
    First I read this blog: [See below]  and typed out commands in order:
    wget http://seyrsnys.myzen.co.uk/rp......1-arm.deb
    sudo dpkg -i omxplayer_0.0.1-arm.deb
    sudo apt-get -f install
    Nothing seemed to happen but the commands did not give an error message.  Then I read and followed:
    wget http://seyrsnys.myzen.co.uk/rp.....bin.tar.xz
    tar xf omxplayer-bin.tar.xz
    sudo apt-get install libva-dev
    sudo ln -s /lib/libpcre.so.3 /lib/libpcre.so.1
    LD_LIBRARY_PATH=omxplayer/usr/lib/omxplayer/ omxplayer/usr/bin/omxplayer.bin dell/temp/test/big_buck_bunny_1080p_h264_ac3.mkv
    but the last command did not work:  "file not found/loction does not exist"
  • GreenYamo
    GreenYamo over 14 years ago in reply to wallarug
    Fergus, forgive me if this is a silly question, but did you download the big buck bunny file as well ? I don't think that the package includes the file.
    Sorry if am asking something obvious.
    Steve
  • wallarug
    wallarug over 14 years ago in reply to GreenYamo
    I didn't, how do I do that?  Is it included?  I got the impression that it was included in the download.
    I have other files I can play.  What are the commands that I can use if the install was successful?
    I am not sure if the install was successful so...???
    Is there a GUI way to load videos?  That would help me alot.
    e14 Contributor over 14 years ago in reply to wallarug
    multimedia is explained in chapter 5 of the RPi User's Manual.
    Unfortunately the RPi User's Manual hasn't been written yet.
    You can download big_buck_bunny from http://www.bigbuckbunny.org/
    the "wget" command is one way of downloading files.
  • wallarug
    Will give it a go later (maybe next thursday).
  • GreenYamo
    Hello Fergus, try
    omxplayer -o hdmi <filename>
    Although I haven't tried it, try using omxplayer /? or omxplayer ?
    It is also worth remembering that a lot of Linux commands have Man(ual) pages, so typing Man omxplayer should get you some information on how to use the commands.
    Steve
  • wallarug
    thanks steve
  • wallarug
    When I enter: "omxplayer /?" or "omxplayer ?"  the terminal window prints: "have a nice day : )" .
    What's with that?  I thought it was funny but annoying at the same time. image
  • wallarug
    Thanks again steve,
    omxplayer works with that command:
    omxplayer -o hdmi <file name>
    before you do that though, you need to change the directory in terminal to where the file is located.
    but otherwise, all good and very helpful support.
    Fergus
    PS: does it player all media types?  it plays .mp4 for certain.
  • wallarug
    wallarug over 14 years ago in reply to wallarug
    I found a useful resource for getting vnc to work.  It might help others.  http://www.youtube.com/watch?v=c5QCoh8S0N4
    Also, tightvnc client will not run the raspberry pi at 24 bit colour. I will investigate.
    Set time: http://www.cyberciti.biz/faq/howto-set-date-time-from-linux-command-prompt/  (for my later use and others)
