Raspberry Pi Forum Computer will not let me log in, then it dies.
  • Subscribers 705 subscribers
  • Views 464 views
chiversj
chiversj over 14 years ago
I turn on the Raspberry Pi and it runs through all the information and when it gets to log in then it will not let me log in. Next thing that happens is another screen of information that ends with: Kernel panic-not syncing: fatal exception in interrupt
Then it is dead. How do I fix this, Thanks Jimmy
  • johnbeetem
    johnbeetem over 14 years ago
    This is mentioned on the RasPi Troubleshooting Wiki and in the RasPi Troubleshooting Forum (you'll have do use the Search function).  A likely cause is an iffy power supply and/or micro USB cable and/or polyfuse F3.  See the RasPi Hardware Wiki Power Supply Problems section.
    e14 Contributor over 14 years ago in reply to johnbeetem
    Jimmy,
    Since your voltage at 4.8v is within normal range, although maybe a
    little on the low side,  I'd suggest trying a different keyboard, or a different
    SD card from the recommended list, possibly a larger SD card if yours is
    2GB where GB=10^9 bytes rather than 2^30 bytes.
    Your error message appears quite often, and doesn't necessarily
    indicate any one specific problem.  You can do a bing search for
      site:raspberrypi.org "kernel panic not syncing"
    to see what others have tried.
    If all else fails, element14 is doing a good job of promptly replacing units
    that appear to be faulty or borderline, and you shouldn't feel bad about
    having to do that, since it gives them better visibility into what's causing problems.
