Raspberry Pi Forum Can I connect Pi to a VGA monitor ?
  • Locked Locked
  • Replies 24 replies
  • Subscribers 711 subscribers
  • Views 8887 views
  • video
mgt6910
mgt6910 over 14 years ago
I don't have a HD monitor (the TV is out of bounds....), so can I connect the Pi's  RCA  or DVI output to
a VGA screen via an adaptor ?   I've found this RCA/VGA converter, but it is designed to work in the other direction ..
http://www.amazon.co.uk/S-VIDEO-ADAPTER-CONVERTER-CABLE-LAPTOP/dp/B000P3UB24/ref=pd_sim_ce_1
  • videogame95
    videogame95 over 13 years ago
    I bought a hdmi cable to vga needs to be a converter cable. I got one for  ten pounds off Amazon you can get better ones for your vga moniter, but it needs to support it if its very old it my not.
  • jamodio
    jamodio over 13 years ago
    I had very good results out from the box with this one from Amazon
    http://www.amazon.com/gp/product/B007SM7O2U
    -J
    And, it's been working for about a week, til I botched something that caused it to refuse to boot further than one of the initializing steps..  Gotta love the looks I get, bringing a small rolling vertical suitcase into the library (My home ADSL was cancelled due to lack of subscribers in the area) , opening it, pulling out the Gateway Monitor, the USB hub, the full-sized keyboard, the HDMI to DVI cable, the mouse, the power supply for the hub, a few extra cables, then a Ethernet cable.. (Oh-Joy! my micro WiFi-N adaptor is not recognized!) , then pull out this dinky little case with the Pi in it, and wire everything up to one of the open Ethernet sockets and a power socket.   The lock-up, resulted in needing to wipe the SD card clean (Ultimate Edition 3.5 on a USB stick, running Disk Utility to wipe the partitions on the card, then re-formatting with a single FAT-32.)...
    a company called CPC do hdmi to vga adapters for £20
