Raspberry Pi Forum troubleshooting topics zooms past 1000 (now 6000)
  • Replies 35 replies
  • Subscribers 708 subscribers
  • Views 4660 views
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=28&t=10869
In my experience, when you have around 10 known issues, you can
discuss the status of each of them in a 1 hour weekly meeting.  You can
easily notice when two are duplicates of each other, and combine them.
You can keep track of which ones have been reproduced, and which
need further information in order to reproduce.  You can keep track of
who is assigned to work each issue, and in what order they should work
them.  You can remember from week to week what the issues are about,
without having to spend all your time coming up to speed again on each
issue.  You can ask whether each issue presents an opportunity to
improve the documentation, or to improve the QA process.  You can
ask to review in detail the proposed fix for each problem, until you are
satisfied that the fix actually solves the problem without creating other problems.
You can ask whether each problem was caused by a fault in the tools used,
or the process used, and if so, whether to make improvements in those.
You can notice when multiple problems relate to the same component,
and perhaps decide to redesign that component rather than continually
patch it.  You can thoughtfully decide whether to deliver a fix as an urgent
update, or wait to deliver it in the next general release.  You can develop
regression tests to prevent the same or similar problems from ever being
shipped again.  And when a problem is fixed and the fix delivered, you
can move it off your agenda.
When you have about 100 known issues, it becomes much more
difficult to do the same tasks.  You can try to prioritize and focus on
just the top 10, but then the others suffer.  When you have about 1000
known issues, it becomes impossible to manage, and you will completely
lose track of which issues are duplicates of others, which are fixed, and
which are urgent.  If you release a product update, you will have no idea
what to say in the release notes.
  • jamodio
    jamodio over 14 years ago
    Agreed, and that is asuming that you have a well trained and dedicated organization which is not the case with RPF.
    We were using JIRA but couple of months switched to Test Track since it has better integration with Surround SCM from Seapine which we use for Software Change Management (version control plus much more), we also use it to keep track of hardware designs.
    No matter if you are a non-profit charity or whatever, my impression is that the whole thing is managed with a lot of amateurism, and by that I don't mean any judgement of technical skills, it is just not professional as it should be.
    I said it many times, the RPF without dedicated and compensated full time permanent staff is just set for failure, and we already experienced how hard is for them to deliver results consistently.
    And it gets exponential, and will get interesting when TV's and monitors start to blow up in schools.
    -J
    Hindsight is a wonderful thing. You have to wonder how many of those issues are caused by two or three design decisions that, in hindsight, were very poor.
    It's easy for us to criticise now, but I wonder if I'd have made similar choices to hit the $25 mark.
    All said though, it's the response to any issues that paints a much clearer picture of any organisation - and that applies to everyone, not just the RPF.  There are some UK xDSL providers that make the RPF look positively wonderful image
  • morgaine
    morgaine over 14 years ago in reply to e14 Contributor
    Their choices weren't driven just by the $25 mark.  If they had been, the CSI/DSI connectors would not be on board.
    They've never explained publicly why those connectors and corresponding layout costs and issues had to be left in while proper power management had to be thrown out to meet the cost target.  It seems that cost was only one requirement, and not a commanding one.
  • jamodio
    jamodio over 14 years ago in reply to e14 Contributor
    I don't think that we are trying to criticise, we are just reviewing, testing, analyzing, reporting and trying to have an open discussios on issues that could be fixed or improved to make the R-pi and its users experience much better.
    Based on the volumes we are talking, even before they realized that demand was much much higher than anticipated, the $25 target, and the credit card size, are just BS. What's the difference between a $25 product that has design and reliability issues to a $28 that works properly ?
    As far as I remember, the community was not invited or welcomed during the hardware design process, not even preliminary schematics were available, errors like the one I found wrongly connecting the VDDCORE pin of the LAN9512 to the 1V8 line could have been corrected before mass production, after going through alpha and beta boards, distributing boards among people I find surprising that there are so many issues being reported, some of which could be hazardous to kids.
    The $25/$35 is really a joke, when you factor in that you need to buy a keyboard, a mouse if you want to work in graphics mode, a power supply or several of them you need to try to make sure they work and don't blow up your TV, a collection of SD cards to figure which one works with your Pi, a powered USB hub (of which some were reported not to work properly) if you want to have some extra stuff or even power hungry USB devices connected to the Pi, the HDMI cable, and if you don't have one, a monitor. Plus if you want to provide some protection to the board, a case.
    What one really can criticise now, is that it does seem that there is no intention to listen, acknowledge and correct the problems.
    -J
  • morgaine
    morgaine over 14 years ago in reply to jamodio
    Indeed.  And since the engineering process starts with identifying problems, that process is effectively dead for the community as far as the hardware is concerned.  It's interesting that the software guys at RPF don't have that mental block.
    e14 Contributor over 14 years ago in reply to jamodio
    criticise was maybe the wrong word... What we're doing though is analysing their decisions in hindsight and thinking we'd have done something better/differently. Morgaine got it right on the CSI/DSI connectors - we really don't know what the design criteria were and they're not about to tell us.
    You're absolutely correct that $28 for something that works perfectly is better. But is it better if it fails the unknown (to us) design criteria ?
    Which is exactly what I was getting at, their reaction to the problems is terrible.
    e14 Contributor over 14 years ago in reply to morgaine
    It's much harder for the software guys to have that block. Especially when someone posts a patch to fix it image
    I do find it interesting that a number of significant software improvements have come from outside the RPF, and that it is encouraging to see them incorporated into the 'official' releases.
  • jamodio
    Well, that's exactly how the GNU community is supposed to work, and there is no need to debate if it is effective or not, just look at how Linux evolved since its early inception.
    -J
    There are now more than 2000 threads in the rpi.org troubleshooting forum,
    over 500 of them by my count are active within the last month.
    The single thread "USB - the Elephant in our Room" has over 500 postings.
    jamodio: "...Based on the volumes we are talking, even before they realized that demand was much much higher than anticipated, the $25 target, and the credit card size, are just BS. What's the difference between a $25 product that has design and reliability issues to a $28 that works properly?..."
    "...The $25/$35 is really a joke, when you factor in that you need to buy a keyboard, a mouse if you want to work in graphics mode, a power supply or several of them you need to try to make sure they work and don't blow up your TV, a collection of SD cards to figure which one works with your Pi, a powered USB hub (of which some were reported not to work properly) if you want to have some extra stuff or even power hungry USB devices connected to the Pi, the HDMI cable, and if you don't have one, a monitor. Plus if you want to provide some protection to the board, a case.     What one really can criticise now...."
    I really couldn't agree more with these sentiments (and the rest of your post). image
    It's all a bit late now but while "cheap and flaky" might be ok for experienced hackers who are looking for a project (or for those inexplicable ebay types who seem happy to take a punt on far Eastern junk that everbody else knows is a ripoff), but most consumers would want "reasonably priced and functions properly" and the UK educational system (which can be likened to an industrial grade customer imo) wouldn't settle for less than "rock solid at a reasonable premium and with Walk On Water support".
    The hardware cost of a classroom's worth of of Pi boards is pretty insignificant compared to the cost of training all those teachers in some pretty deep topics. Then there's the cost of peripherals and accessories for e.g. GPIO interfacing, study materials, SD card duplication, all those thousands of meetings...
    It made no sense to cheap out on the board to the current extent, but now that it appears to be pretty much finished then it makes even less sense to cheap out on getting it working bess poss. One guy with a USB sniffer devising workarounds in his spare time? Remember that the Foundation were initially hoping to shift 10,000 units eventually to finance the educational push. It now looks like that sales target will be exceeded by two orders of magnitude.That should pay for some development time. Or a new kitchen.*
    I'm sure this soap opera will run and run.
    *in-joke.
