Raspberry Pi Forum How do I download more software packages to Raspberry Pi?
  • Subscribers 708 subscribers
  • Views 708 views
  • downloads
  • download
  • software
dharr19
dharr19 over 14 years ago
I have installed the debian6-19-04-2012.img to my SD card.  Once I get everything up and running, how do I download more software packages?
Cheers
David
    David,
    I haven't used the debian yet, but have you tried using apt-get yet? I'm pretty sure it still uses apt-get, so as root run apt-get install [package you want installed], first you might want to run apt-get update && apt-get dist-upgrade
    Hope that helps.
  • morgaine
    morgaine over 14 years ago
    You can do pretty much everything you need in basic package management with just two commands, "apt-cache search" and "apt-get install".
    Beyond that, see the respective man pages for a few more option flags ("man apt-cache" and "man apt-get"), and your commandline package management abilities will become really quite powerful.  And finally, have a good read of "man dpkg" and you'll be ready to start training for guru status. image
    Alternatively, aptitude gives you the same kind of package management but with an ncurses-based semi-graphic interface on a terminal session, while synaptic provides an equivalent graphics interface under X11.
    Morgaine.
  • wallarug
    wallarug over 14 years ago in reply to morgaine
    I tried to use "apt-get install tightvncserver" but it returned the message:
         E: Package < tightvncserver > has no installation candidate
    How can I get tightvnc then?
    BTW: This is only with the Wheezy image and NOT the Squeeze image.
  • dharr19
    dharr19 over 14 years ago in reply to morgaine
    Thank you for your help.  The only other thing I would ask is, what is the highest class SD card that Raspberry Pi can use?
    Cheers
    David
  • wallarug
    wallarug over 14 years ago in reply to dharr19
    I use a 8 GB class 10 SD card
