Raspberry Pi Forum tightvnc at start-up ?
  • Replies 11 replies
  • Subscribers 707 subscribers
  • Views 1556 views
  • tightvnc;
  • vnc;
  • raspberrypi
  • server;
  • raspberry;
  • pi;
wallarug
wallarug over 14 years ago
How do I enable tightvnc at start-up without having to type te command each time and log-in?  What file do I add to? is it the /etc/modules file? If so, what do I add?
Normally when I start a tightvnc server session, it loads the GUI on the viewer.  Can I change this aswell?
This is what I normally type: "vncserver :1 -geometry 1280x800 -depth 24"
  • wallarug
    wallarug over 14 years ago in reply to recantha
    Michael Horne wrote:
    On Debian, you add a command at the bottom of /etc/rc.local, but ABOVE the exit command on the final line.
    What you need to add is:
    su -c "vncserver :1 -geometry 1280x800 -depth 24" root
    That _should_ start it up before the login prompt so you can use a VNC viewer to get into it.
    I _think_ it's su. If that doesn't work, try sudo instead
    If you wnat a different user account, change the "root" to pi at the end of the command. image
