Raspberry Pi Forum tightvnc at start-up ?
  • Replies 11 replies
  • Subscribers 707 subscribers
  • Views 1544 views
  • tightvnc;
  • vnc;
  • raspberrypi
  • server;
  • raspberry;
  • pi;
wallarug
wallarug over 14 years ago
How do I enable tightvnc at start-up without having to type te command each time and log-in?  What file do I add to? is it the /etc/modules file? If so, what do I add?
Normally when I start a tightvnc server session, it loads the GUI on the viewer.  Can I change this aswell?
This is what I normally type: "vncserver :1 -geometry 1280x800 -depth 24"
  • recantha
    recantha over 14 years ago
    On Debian, you add a command at the bottom of /etc/rc.local, but ABOVE the exit command on the final line.
    What you need to add is:
    su -c "vncserver :1 -geometry 1280x800 -depth 24" root
    That _should_ start it up before the login prompt so you can use a VNC viewer to get into it.
    I _think_ it's su. If that doesn't work, try sudo instead
  • wallarug
    wallarug over 14 years ago in reply to recantha
    Will try image
  • wallarug
    That looks good, But, I can't find the double inverted comma's  "[text]"  On my keyboard.
    That key is the # key and I can't find the " key.
    Can you help fix this?  I don't know what keyboard type I have.  It has a $ sign on number 4.
  • electron2
    electron2 over 14 years ago in reply to wallarug
    it seems that you have a US keyboard you may have to change the keymap.
  • wallarug
    wallarug over 14 years ago in reply to electron2
    I got the vnc to start on start-up.
    thank you.
    but I can not change the keyboard map.  What is the command to get the "box" that first comes onto the screen the first time you start-up raspbian?  Then I can fix this issue.
    Thanks in advanced
    Also, I can't seem to mark your responce as the correct answer.  Maybe post the same message so I can attibute this to you.
  • recantha
    recantha over 14 years ago in reply to wallarug
    Try
    raspi-config
  • wallarug
    It didn't want to run the configure keyboard section.:
    There was an error running do_configure_keyboard.
    updating as I speak...
  • wallarug
    wallarug over 14 years ago in reply to wallarug
    No luck image - updating did not fix the problem.
  • wallarug
    Got it!  now which keyboard do I have? image
  • wallarug
    CLOSED
