Raspberry Pi Forum I have problem with my Raspberry
  • Replies 7 replies
  • Subscribers 706 subscribers
  • Views 810 views
Hi! I have problem with my Raspberry. When I start  my raspberry it doesn't strart up at all, no imiges on the screen. Please help me to solve this problem. I  followed all steps in user tutorial.
    Sergey,
      There are some suggestions, and a link to the troubleshooting guide at:
    http://www.element14.com/community/message/54714#54714/l/re-got-my-raspberripi-yeah-cant-load-the-debian-software-boo-help
    Hi! Thank you for your answer but before I could strart it without any problem. But now I don't really know what's happend with my raspberry. I tried to reinstall debian again but still the same problem.
    sometimes using a new SD card will make it work.  sometimes you have to send it back for a replacement.
    Thank you again! I will try to change sd card.
  • GreenYamo
    GreenYamo over 14 years ago in reply to e14 Contributor
    Hello Sergey,
    You mentioned that 'Before you could start it without any problems' - can I ask what this was before - did anything happen or did anything change ?
    This may help in working out what has gone wrong :-)
    Steve
    e14 Contributor over 14 years ago in reply to GreenYamo
    Hi! Before I didn't have any problems to start my rasberry but now it doesn't start at all. The red button is flashing. I tried to format the sd with SDformatter and install debian again but still the same problem. No image at all. if i understand the green light has to flash as well after start. I can send you photos if it helps to solve this problem. First of all I thought that the problem with SD but my computer recognaise it. Please help me to solve my problem.
    My regards,
    Sergey
    Do you mean the red led labeled  PWR is flashing on/off ?  If this is the case then it's likely to be a power problem. Can you check if RG2 or F3 is getting hot ?  Also try disconnecting all USB devices.
    Is your power adapter output rated for 5v 1A ?  or less ?   If all else fails, can you try another power adapter ?
