Raspberry Pi Forum Game controls via the GPIO connector?
  • Subscribers 705 subscribers
  • Views 386 views
segadude
segadude over 14 years ago
Basically I am going to build a game system inside a Sega Game Gear case.  Would I be able to utilize the GPIO for the buttons? Maybe use small mircoswitches under the existing buttons that could somehow be interpreted as key presses via the GPIO?
  • johnbeetem
    johnbeetem over 14 years ago
    Yes, GPIO inputs should work fine.  You'll probably find everything you need at the RasPi Wiki, starting here: http://elinux.org/RPi_Low-level_peripherals.
    Be very careful with GPIO pins because they're directly connected to the SoC and can easily damage it.  In fact, the first thing you should do is to strip a short piece of insulation off a wire and push it over the +5V pin so you don't accidentally short it to one of the other GPIO pins.  The RasPi Wiki has more detailed warnings.
