Raspberry Pi Forum Does Anyone know where to get a RPI touch screen From?
  • Replies 30 replies
  • Subscribers 695 subscribers
  • Views 4062 views
  • helpme
  • element14
  • pi
  • rip
  • touch_screen
  • raspberrypi
  • raspberry_pi_accessories
Mrjdy1
Mrjdy1 over 13 years ago
Hello can anyone find a touch screen that is not that expensive that would work for the Raspberry Pi Model B? Thanks
    I have was able to find 7" and 10" touch screen displays.  I purchased the 10" and am very happy with it.  The set up was extremely easy and it worked right away, even before calibrating.  I have a model B rPi and decided to try and build a debian linux powered tablet.  I purchased a lithium ion battery to power everything and included a 4-port usb hub and an HDMI splitter so I can mirror my screen on a tv or projector for presentations.  The 10" screen works perfectly for my set up right now, although I'm still working on designs for a case to house all the components.  I've decided to print a case using a 3D printer rather than trying to cut one out of any other material.  I'd like to keep this as slim and lightweight as possible.  If anyone knows anything about 3D printing, I'd love some tips.
    7" display - $124.99
    10" display - $134.99
    Both include:
    Touch Screen
    Assembled HDMI-LVDS converter (makes the screen a touch screen)
    All necessary wires for connecting to the rPi
    *MUST BUY RPI SEPARATE*
    Once purchase, simply follow these instructions all the way through calibration and you're set to use your finger as a mouse.
    If you want a touch screen keyboard:
    Type into terminal:
         <sudo apt-get install matchbox_keyboard>
    Or follow these instructions
    I have only 2 complaints:
    1) I've had trouble using a usb connected mouse with 'ghost movements' causing the cursor to jump all over the screen.  Further research revealed a way to calibrate the sensitivity of the touch screen, but I also found out that whether or not the screen is properly embedded in some sort of a casing actually does make a difference. Instructions of how to calibrate and more information on the cause of the problem can be found here http://www.chalk-elec.com/?p=1702.
    2) I've also had trouble with using my finger to click and double click.  It seems that every time I touch the screen, it instinctively thinks I'm trying to drag and move icons around on my desktop.  I'm wondering if that's also an issue with having a free standing screen.
    If you need any help send an email, im ngdouventzidis@gmail.  I have never used this site before, just came across this thread and registered with the site so I could help.  Good luck
  • fustini
    fustini over 13 years ago in reply to Former Member
    thansk for sharing, I've been curious about those Chalk Elec products.
  • pjc123
    pjc123 over 13 years ago in reply to Former Member
    "I purchased a lithium ion battery to power everything and included a 4-port usb hub and an HDMI splitter so I can mirror my screen on a tv or projector for presentations."
    According to the instructions on the site for this panel with the raspberry pi,
    http://www.chalk-elec.com/?p=1576
    the panel and circuitry requires a 2 amp power supply, separate from the pi's power supply, so I suspect your run time must be pitifully short.  What battery are you using, what is your run-time, and what is the measured actual current draw of the panel and associated circuitry?
  • tthomas
    tthomas over 13 years ago in reply to fustini
    I have purchased several 7 inch touch screens from www.Lilliput.com.
    Their model 765 works great with the Pi.  Be sure to remake the OS to
    include the correct driver. I'm using a Slackware distro.
  • pjc123
    pjc123 over 13 years ago in reply to tthomas
    Lilliput 765.  $300.00....WOW.
    Former Member over 13 years ago in reply to pjc123
    The HDMI LVDS board is what gets powered, then the pi is powered through that using a short usb cable that came with the screen.  That is a concern of mine though, but the usb hub is mainly going to be used for external desktop harddrives with their own power source and the occasional 2g flashdrive.  The HDMI doesn't supply power, and tvs and projectors have their own power supply.  The battery is just a cheap 20 dollar battery, i'll have to find a link if you'd like.  Im not a computer genius, in fact I'm majoring in environmental studies, i just wanted something to use for presentations and to take documents to and from class.  When I take the time to improve the design, the plan is to try and adapt a much more powerful battery, like a laptop battery, but that is off in the distant future.  At the moment, I don't have the battery connected, I need to purchase adapters to connect to the LVDS board.
  • tthomas
    tthomas over 12 years ago in reply to pjc123
    Lilliput has dropped their prices.  I have purchased 4, 5 and 7 inch touch screens and am placing an order for 15 inch all touch.  I have had to use the HDMI port with a HDMI to VGA converter for most of the units.
    Former Member over 12 years ago in reply to pjc123
    If you are referring to touch screen remote for video/audio, I have the RPi with XBMC (Raspbmc) Frodo mainly for video library located on NAS and working quite smoothly and use both Samsung 500T and Lumia 620 with their respective XBMC RC apps for touch screen remote control.  Similar XBMC RC apps are available for IOS and Android.
    Former Member over 11 years ago in reply to Former Member
    The smaller touch screens are much cheaper: 3.2" http://www.ebay.co.uk/itm/3-2-TFT-LCD-Module-Touch-Screen-Monitor-Display-for-Raspberry-Pi-B-B-dll-/311163532881?pt=UK_Computing_Other_Computing_Networking&hash=item4872cab651
    or 3.5" http://www.ebay.co.uk/itm/3-5-TFT-LCD-Touch-Screen-320-480-RGB-Monitor-Display-Board-F-Raspberry-Pi-B-B-/171636208809?pt=UK_Computing_Other_Computing_Networking&hash=item27f650b4a9#ht_3399wt_880
  • royleith
    royleith over 11 years ago
    It depends what you are wanting it for, but there is this one;
    RPI2.8TFTB+ - PI SUPPLY - RASPBERRY PI TOUCH TFT | CPC
    RPi Display 2.8? TFT Touch Screen for Raspberry Pi Model B+  £34.99
    Extend your Raspberry Pi Model B+ with a 2.8? full color display (320×240) with touch panel. There is a framebuffer driver available for this display, so you can use it right out of the box.
    • TFT-Display: 2.83?, 240×320 (Transmissive)
    • Viewing area: 43.2 x 57.6mm
    • Touch Controller: TI ADS7846/TSC2046
    • Backlight dimmable (PWM)
    • Interface: SPI (Touch Controller + Display)
    • 3 tactile switches
    • GPIOs available via 40 pin FFC/ZIF-Connector
    • Power: 5V
    • Raspberry Pi Model B+ Pinout
    • Fully assembled
    For Raspberry Pi B+ only
