Raspberry Pi Forum I can not get Wheezy to work on Pi
  • Subscribers 707 subscribers
  • Views 683 views
chiversj
chiversj over 14 years ago
I downloaded Wheezy and I used the Win32diskmanger and I see the file with a IMG extenstion on my SD card, but the Raspberry Pi just sits there and the green led does Not blink. Help, Thanks Jimmy
  • johnbeetem
    johnbeetem over 14 years ago
    A good starting place is the RasPi Wiki Troubleshooting page: http://elinux.org/R-Pi_Troubleshooting
    If you can see the img file on the SD card then this is the problem. The img needs to be written to the SD card so that its contents (its basically a complete file system)are on the SD not the img file.
    Have a look on the RPi forums & wiki for help on how to do this.
  • GreenYamo
    GreenYamo over 14 years ago
    Jimmy,
    As above, if you can see the img file on your SD card, that is the reason for problems. See this guide on the Rpi site
    http://elinux.org/RPi_Easy_SD_Card_Setup
    To precis, download the image, stick the SD card in your pc, open Windisk imager, browse to the image file, select the correct disk to write to (Not your C drive) write the image out, put the card in the pi, things should start happening.
    Steve
    e14 Contributor over 14 years ago in reply to GreenYamo
    Is there really nothing better than this win32diskimager available for windows ?  The number of posts that are appearing where it seems to be the common denominator for a non-working Pi has me wondering if it isn't the biggest problem here.
    i'm haveing the same problumimage
