Raspberry Pi Forum USB discussions getting a bit heated
  • Replies 87 replies
  • Subscribers 710 subscribers
  • Views 16502 views
On the other forum, discussions of USB and networking problems have been
getting a bit heated recently, with one user, Sulge, banned yesterday by abishur
for a 1-week cooling off period.  Maybe we will see him here soon.
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=28&t=12097&start=177
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=24&t=14151
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=28&t=5249
Some of the USB issues are being blamed on Linux latency, which
doesn't sound easy to fix.
    e14 Contributor over 14 years ago in reply to morgaine
    ah ha Morgaine!  We may be "clueless" and walking around in the dark - - - but we sure know how to find someone with a lightimage
    great explanation to @David.
    Best
    peg
  • morgaine
    morgaine over 14 years ago in reply to e14 Contributor
    Funny comment, Peg, but I hope the references to 'clueless' weren't misunderstood. image
    The 'clueless' aren't those who don't know --- the more you know, the more you realize that you don't know, so not knowing is not the defining property.  It's only those who don't wish to know and don't wish to think, or cannot think.
    Walking around in the dark is what we all do, but the desire for illumination is what takes us to the nearby planets today, and one day to the stars.  Civilization is all about riding on the shoulders of those who went before, so if you know how to find someone with a light then you're helping to carry that torch forward and build that pyramid of knowledge and capability.
    Welcome to the dark.  But as you said so well, we sure know how to find someone with a light.image
    Morgaine.
  • jamodio
    jamodio over 14 years ago in reply to morgaine
    Let me clarify the context related to my "clueless" comment.
    I have no issue or problems with people that don't have a clue and are asking the right questions and in a proper manner. I've been clueless and I'm clueless in many many things and we all at sometime are "newbies." That's not the issue.
    The issue is with a forum where moderators are supposed to, among other things "moderate" some comments so wrong information doesn't get widespread.
    In the case of the R-Pi forum if somebody states something like "The chips in the RPi are supposed to run hot, they are designed to operate safely to 120 degrees C," I've not seen any moderator or anybody from RPF to reply to that comment so the clueless person that made it can get un-clueless, or even providing the right information about what is the correct operating temperature range for the R-Pi and its parts.
    On the other hand people reporting real problems, and providing valuable information, get bashed, harassed, called names and banned.
    This is from where my "clueless" comment came from.
    -J
    e14 Contributor over 14 years ago in reply to jamodio
    All,
    I got a kick out of the clueless thing!! Hope you didn't misunderstand my compliment!
    I have learned so much in the last few months - and it's from reading then researching, then doing after you have explained or discussed something. . .
    My thanks to you all - keep the light comingimage
    peg
    Morgaine. . . I've become a fan of yours...please see my reply to jamodio
  • morgaine
    Yay, I have a fan!  I'm not sure what to do now, I've never had one before. image
    PS. I can't improve on your last line to jamodio --- "keep the light coming".  That's glorious! image image
    One light that stays off is that of the backfeeding usb hubs. If the Pi is powered from the a downstream port of the same hub, wouldn't that basically ensure that the Pi receives the full voltage, and shouldn't it boot normally, besided getting some voltage as well on one of it's usb ports? This would basically just short the main and usb polyfuse on the board. But reading from reports, people say that keyboard and mouse behavour is bad with a hub providing power to it's upstream port. This doesn't make sense.
    Considering the power negotiation of usb ports. When you run into issues on a windoze pc, it simply shows a warning message that a device needs more power and should be connected to a self powered hub. Since the driver is not loaded, the device can't start to consume the power it needs. The usb port will keep providing current untill a Polyfuse trips (or some other protection turns on.) On cheap mobo's, they will even provide just one 1Amp fuse for 2 usb ports. It will have a lower resistance under normal operating conditions, and power hungry usb harddisks will work as long as the second usb port isn't badly loaded as well. Maybe it's an idea to improve the price on the Pi2.
    e14 Contributor over 14 years ago in reply to johnbeetem
    Well, I don't think "channel" is a USB term.
    No, I get the impression it's some internal design detail of the controller.
    That is, as soon as one transfer completes that "channel" is available for a new one.
    If I'm reading it correctly, that's the problem. Things that require a 'channel' consume one permanently with the current driver. Looks like there are fixes for that in the code that's in the process of being upstreamed into 3.6, but that needs backporting effort to get it into 3.1.9.
    If the upstream dwc_otg driver effort succeeds the sensible path would seem to be to move forward to a mainline kernel. AFAICT the only missing pieces are usb and the vchiq thing that will likely never be accepted upstream anyway. Forward porting vchiq and keeping it up to date seems like it should be less work than continually backporting all the different parts into 3.1.9.
    Although it's possible that neither forward or back-porting efforts are worthwhile until the current high churn rate in the arm tree settles down.
  • dharr19
    dharr19 over 14 years ago in reply to morgaine
    I connected my bluetooth to my Mac and I get a power light.  When I connected it to my Pi nothing happened as before but while it was on I checked my voltage and it was 4.89 so at this point I'm not sure.  Any ideasimage
    Cheers
    David
  • johnbeetem
    johnbeetem over 14 years ago in reply to dharr19
    I don't know anything about bluetooth other than it's wireless and local, but here goes: are you plugging the bluetooth dongle directly into a RasPi USB port or into an externally-powered (self-powered) hub?  Is your 4.89V measured at TP1-TP2 (4.89V should be fine) or at the USB port, i.e., on the USB port side of F1 or F2?
    If the dongle requires more than 100mA the voltage drop across F1 or F2 may be too much for the dongle.  Also, the dongle may require even more current when transmitting -- you may only be able to see this on a 'scope.
    Just some ideas -- I don't know bluetooth specifics.
