Raspberry Pi Forum PWM audio driver source code for Raspberry Pi
  • Subscribers 697 subscribers
  • Views 2480 views
shabaz
shabaz over 13 years ago
(Still getting to grips with this site, created a blog entry by mistake!)
Apologies if this is the wrong location on the forum.
I'm new to Linux driver coding (but very experienced in application coding in C and C++).
I've spent some time searching for source code for the rasp-pi.
I was wondering, where can I find the source code for the PWM audio driver?
(that is used for the on-board audio, not via HDMI).
I've found this location:
https://github.com/raspberrypi/linux/blob/rpi-patches/sound/arm and I think the function
I'm looking for is called bcm2835_audio_write but I don't know where that function source code
resides.
Any quick pointers to direct me to the particular file I should be looking at would be much appreciated.
Thanks!
  • fustini
    fustini over 13 years ago
    Hi, not sure if this is what you need, but I happened to be reading this post by Adafruit just before seeing your post:
    • New! Adafruit’s PWM/Servo kernel module for easy PWM/Servo control on GPIO#18
    http://www.adafruit.com/blog/2012/08/31/update-occidentalis-v0-2-adafruits-raspberry-pi-educational-linux-distro/
    Looking at their github repo, there are several recent commits for pwm:
    https://github.com/adafruit/adafruit-raspberrypi-linux/commits/rpi-patches/
    The last commit was to:
    drivers/misc/rpi-pwm.c
    https://github.com/adafruit/adafruit-raspberrypi-linux/commit/4a41db242545d5f86f8a759d81f4ee1b915bd461
    cheers,
    drew
    Hi shabaz!
    Have you solved this problem?
    I have the same problem, I need a PWM signal to 200 KHz for libraries but I use can only generate a PWM signal from 5 KHz (according to my oscioscopio).
    Will you kindly give me guidance.
    Thank you
    toto
    shabaz over 11 years ago in reply to e14 Contributor
    Hi toto,
    Unfortunately I abandoned efforts to use the audio when the BeagleBone Black came along (it has hardware capabilities useful for PWM and separate processors for high-speed I/O).
    However on the RPI, I notice there is some code here which states it uses some "semi-hardware pulse width modulation"? This might be a better approach than using audio.
    "RPIO.PWM provides PWM via DMA for the Raspberry Pi, using the onboard PWM module for semi-hardware pulse width modulation with a precision of up to 1µs."
