Raspberry Pi Forum RPi rev 2.0 explained
  • Replies 55 replies
  • Subscribers 709 subscribers
  • Views 8513 views
Eben has a front-page story up explaining rev 2.0.
It does fix the 1.8V problem, although no credit where
credit is due to Jamodio or any of the others here for
finding, characterizing, and reporting the problem.
No mention that I can see of FCC/CE residential
certification.  I assume the needed minor pcb changes
were made, but perhaps certification has not been
done yet.
http://www.raspberrypi.org/archives/1929
p.s.
   hopefully element14 will explain to their customers
how to be sure to get rev 2.0 when ordering.
  • wallarug
    wallarug over 14 years ago in reply to jamodio
    Where is P6 that this article talks about: http://www.tweaktown.com/news/25700/raspberry_pi_revision_2_0_boards_announced/index.html
    e14 Contributor over 14 years ago in reply to wallarug
    P6 is the un-populated 2 pin one between RG2 and the HDMI connector.
    Anyone see a P4 ?
    e14 Contributor over 14 years ago in reply to jamodio
    Glad to see that the voltage regulators are from ON Semi and not the cheap chinese knock off,
    I was wondering if you'd notice that image
    Was there a matching pic of the underside of the board ?
  • wallarug
    wallarug over 14 years ago in reply to e14 Contributor
    Anyone see a P4 ?
    That makes sense now.  Thank you.
  • jamodio
    jamodio over 14 years ago in reply to wallarug
    It is right next to the 3.3V regulator, probably is the header for the reset button.
    -J
  • johnbeetem
    johnbeetem over 14 years ago in reply to e14 Contributor
    selsinork wrote:
    Anyone see a P4 ?
    P4 is the Ethernet jack.  Silkscreen label is under it.  Use your X-ray vision or look at photo of unpop'd board or the schematics.  Yes, P4 is an inconsistent name since RasPi generally uses "P" for plugs and "S" for sockets.  Maybe they used "P" because the preferred vendor was Pulse Engineering... "OK, you explain it then" [Eddie Izzard].
  • johnbeetem
    johnbeetem over 14 years ago in reply to wallarug
    Fergus Byrne wrote:
    Lets hope they start populating P5 shortly.  Thanks for the reply. image
    P5 is intended to go on the back side of the board.  If you populate it on the front, there's not enough clearance for standard IDC connectors.  If you populate it on the back, RasPi 2.0 won't fit in a lot of cases.  So better to leave it off for now until the Element14 discussion group comes up with the right way to do it image  My personal preference is 2mm connectors, but then I learned the metric system at an impressionable age.
  • johnbeetem
    coder27 wrote:
    I wrote:
    >No mention that I can see of FCC/CE residential certification
    Much to my surprise, Eben says that Class B FCC/CE certification
    will have to wait for the educational release board.
    http://www.raspberrypi.org/archives/1929#comment-31756
    Back on May 31, Eben said: "there's pcb level work going on
    at the moment to accomplish that".
    http://www.youtube.com/watch?v=WIf4Fk2252A
    starting at about 17:35
    Liz has said on April 10, 2012 at 7:04 pm, in page 3 of the
    comments to this article: http://www.raspberrypi.org/archives/978
    "Happily, we’ve found it doesn’t need a shielded enclosure to
    reach Class B, although it will require a (very minimal) redesign."
    If the redesign really is "very minimal" and was underway as of
    May 31, I'd expect it would have been included in rev 2.0.
    My guess:  It may be that they've made the changes on the 2.0 board, but they haven't gone through recertification yet.  Certification is expensive and painful.  If you haven't changed much on a board, and in particular you haven't changed the circuits for the external interfaces or their locations, you can often get by with a document review rather than full testing.  Might as well wait to be sure RasPi 2.0 hasn't missed anything before recert.
    e14 Contributor over 14 years ago in reply to johnbeetem
    You're right - I just happen to have one here that I've removed most of the connectors from...
    Nice pic of the back on the skpang blog here http://www.skpang.co.uk/blog/archives/701 I see that there's an extra lump of copper underneath the lan9512 as well.
    Certainly appears that these ones go over a wave on a carrier - you can clearly see the outline in the flux residue.
    Slightly concerning that D10 & D11 appear to have vanished - that's likely to scupper my plans to add an AP1212 usb switch.  Schematics would be nice...
  • johnbeetem
    Yes, that's a nice picture.  I see that the P5 label is on the back side, not the front.
    The extra copper under the LAN9512 should help with radiating heat or conducting it using a thermal pad.  I'm glad they finally acknowledged that the LAN9512 presents thermal challenges.
